Originally Posted by Panther
(Post 3899833)
You're getting the itch already?
#4 drives
Mark,
Yes it was Scott Rutherford and I that stayed in your condo and had a wonderful ride in the Apache. Gary |
Originally Posted by no issues
(Post 3899729)
Hey Sean... check out this pic... I always wondered how this set up worked out. If that boat did a re-enter ass down.. you would think the transom would rip out right? The notch is in the boat and the surface drives are hangin out past the transom.
Am i missing anything? Thanks Eric |
(Post 3899729)
Originally Posted by RMPRam
(Post 3899956)
Mark,
Originally Posted by sean stinson
(Post 3899612)
Just make sure they get rid of the notch in the transom first....That way you can get the Arnesons all the way to the bottom
Originally Posted by Rik
(Post 3900346)
Technically for a full Stagger but for a standard side by side or even a short stagger could use a filler panel only where the drives are mounted so that they mount correctly.
Originally Posted by TURBO JET
(Post 3900371)
When you say filler panel do you mean a panel that is bolted in place of the notch or is the panel glassed in. Do you have any pics of how the panel is filled in. I would just like to see how involved it is and if the integrity of the transom is compromised. Just trying to picture it. Thanks
Don't have access to photos at this moment. |
| All times are GMT -5. The time now is 02:04 PM. |
