Winter Upgrades >
Winter Upgrades
Winter Upgrades
Old 09-29-2005 | 10:47 AM
BajaRunner's Avatar
Default Re: Winter Upgrades
Dock
what kind of speeds are you seeing out of your new motors?
BajaRunner is offline
Old 09-29-2005 | 02:15 PM
nomomoney's Avatar
ya'll should use LED lights instead of neon.they are much brighter,and they don't draw any watts at all.i have about 15 -3 light clusters in my 38 and they rock...they are even water proof..
nomomoney is offline
Old 09-29-2005 | 02:29 PM
Dock Holiday's Avatar
Charter Member #34
I have 12 LED's in the boat now. One in the bottom of every cup holder and in the engine compartment. They are AWESOME!
But the Neon's are the ones that wire into the stereo and dance with the music. They are computer controlled with 1000 colors and are simply awesome to watch!
Dock Holiday is offline
Old 09-29-2005 | 02:32 PM
Charter Member #34
Originally Posted by BajaRunner
Dock
Last weekend on the flat waters of the Tennessee River with full load of fuel, four people and at least 500 lbs of gear I saw 72 on the GPS.
Hope to run it lighter, in the cooler weather this weekend and see where it is at.
Tyler Crockett did the ECU's a couple of weeks ago and it really woke them up.
Old 09-29-2005 | 07:50 PM
29goingon42's Avatar
Originally Posted by JaayTeee
Repair the hatch.......After the Shootout incident
Throw a upper gear set in the r/h drive, so
it doesn't explode ( like it's neighbor did) next
year.
I'd like to find a set of 2" shorties, since
I've ran it with 5 blades, it hooks up, guessing
there's more speed if you get them up.
Jaay, I saw your boat without your hatch attached coming back but I didn't see your run, I thought to myself...self..... that must be a Baja thing... . You really need to post that video for all to see and learn and what was your final speed.
thanks
29goingon42 is offline
Old 09-29-2005 | 07:57 PM
RollWithIt's Avatar
New starter, fix the trim tab leak and a couple other minor issues.
RollWithIt is offline
Old 09-29-2005 | 08:42 PM
JTB
My winter upgrade will hopefully be a bigger boat!!
JTB is offline
Old 09-30-2005 | 05:59 AM
AIR TIME's Avatar
replace cracked rear bulkhead and add one to the front,replace some of the floor its softin the bilge area add swim platform ,making new dash that glasses in to the floor with steps 2'' shortie, to see if I can get rid of the chine walk after74mph or when I hit a wake side ways and use my 647hp to its max it is a 88thats been in offshore races,pokerruns soit needs some tlc this winter ps the last to years I have replaced and added floorcenter ribs ,ex steering, light weight engine cover with pro stock scoop Ihope to hit the water this weekend to try my labbed 26p prop since its two years old ART
AIR TIME is offline
Old 09-30-2005 | 08:21 AM
thebigtman's Avatar
Well, I just finished my second rebuild of the season...that's enough for now. When I get motivated I'll start thinking of redoing my hatch too. It kind of bends to the starboard side since the actuator is on the port side. Anyone have any suggestions on how to fix it?
thebigtman is offline
Old 09-30-2005 | 09:09 AM
JasonSmith's Avatar
Short of going to the side mount hatch actuators, there is not much you can do to eliminate the Baja lean on the hatch. I had a 226es that did the same thing. I found mine was full of water and weighed over 150 lbs! Needless to say I tore it apart and had an all fiberglass one made.
JasonSmith is offline
