Anyone with a 36 calculate your prop slip?
#51
Not yet. I sent my carbs to mesa balancing to rework. Im having the a/c pickup removed, and bungs installed the the risers to check a/f ratios. should have it wrapped up in the next 2 weeks, then ill try all the props and get with throttle up to do the final dial in.
#53
Originally Posted by baja36ft
I Know They Changed The "x" In 2001 (on The 36)but Did Testing In
99 My "x" Is The Same As A 2002 A Friend Of Mine Has A
99 25 Outlaw And His "x" Is Higher Then The 2001 We
Measured So Go Figure Thats Why The 2 Inch Shorties Did Not Work For Me That I Thought Would For Sure I Thought My "x" Was 1.5 Lower Then It Was.
can you measure your "x" Im going to check mine and see where its at.
#54
Originally Posted by BajaRunner
hey stan
LINES GO IN )WAS 6 OR 6 1/2
WHAT DID LAZ DO TO YOUR CARBS??
DO A SEARCH ON IMCO SHORTIES I ASKED DOCK TO MEASURE HIS.IT SHOULD BE ON THERE .
#55
I just heard from laz, he said my carbs were jacked up. the metering block was plugged on one, someone switched the powervalves from the stock 4.5's and put in 6.5's. He thinks ill get anywhere from 200-400 rpms when i get them back. Im hoping to try it next weekend and i should have the a/c pickup off by then.
#56
#57
STOCK IS 6.5.
