Anyone with a 36 calculate your prop slip?
#71
Originally Posted by BajaRunner
are you running gils or an aftermarket exhaust?
I was told by several, including the tech at Crane that reversion would not be an issue.
#72
Originally Posted by Dock Holiday
The stock CMI headers that came on the 500EFI with straight CMI 4-1/2 inch tail pipes (dry) dumping at the end. They extend out about five inches beyond the transom.
#73
Laz Mesa just called, carbs are on the way back. He said he cleaned up the idle circuit and did something with the powervalve circuit. over my head.
#74
Ahh, I have the crappy gils then. I didnt want to spend the coin on exhaust.
#75
Get your circuit's crossed and you are screwed!
Good luck buddy
#76
Just ordered the HVH 1" supersuckers, be here by friday
I also ordered a can of mercury blue spray paint to touch the carbs up, $25 freakin dollers for 1 can
#78
Originally Posted by baja36ft
Good Luck I Use The 2 Inch Spacer Picked Up Alittle
More On The Dyno With The 2 Vrs 1 But You Have To
Jet Up. What Is The Timing Set At?
what difference did you see? (2 vs 1)
#79
Ill be testing this weekend. Got a set of 26's and 28's, also going to try hydromotive 26's and since i have the lower "x" im going to try 27 and 29 mirages.
damn thats a bunch of prop changes. Ill report the news. I should figure out what works best and get a set of props going.
