-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   30 outlaw (https://www.offshoreonly.com/forums/baja/126957-30-outlaw.html)
r1ver_rat 07-21-2006 01:53 AM
Re: 30 outlaw
Originally Posted by Busta
Is that a gps speedo? What's your weather like there (outside temps)?
My speeds are with the liquid speedo not GPS. As for weather it approx 120 at 8% humidity. I wonder if taking out rake or cup in the props would help or raise the lowers by 2"
Dock Holiday 07-21-2006 07:34 AM
Re: 30 outlaw
You might get away with 1 inch shorter. Baja has not done well with 2 inch shorter on their standard hulls.
The 2 inch shorter work better with cats and stepped hulls that run more level, then you had 5 or 6 blade props.
BajaRunner 07-21-2006 07:42 AM
Re: 30 outlaw
especially with the newer "higher" x dimension boats. My 2000 might be a candidate for a 2" shorty, then it would be closer to your "x" doc.
Reds Outlaw 07-21-2006 07:00 PM
Re: 30 outlaw
My test run was done in Southern Quebec, Canada on the Richeleau River and the temp was about 78 degrees that day. The water was calm and just a slight breeze. My speed is with a standard speedometer.
Red
SOX 07-23-2006 08:30 PM
Re: 30 outlaw
1 Attachment(s)
I just got a ride in a brand new '07 with about 4 hours on it. The boat is completly stock and we had it WOT for under a minute and we ran 75gps. Again we didn't have it wide open very long so witha little trim and tab work I am sure it has more to go. This boat is also getting a set of CMI's installed this week which they are guessing it will break 80. I was really impressed with the boat overall. I may be wrong but I think it is the first year using a liner system. We ran that boat in 2-3 footers and it was rock solid. It is for sale for $150k. a little rich for my blood but I think it's worth it.
Mike is the sales manager at Triton Marina and takes good care of his customers. Tell him I sent you.
http://www.tritonmarina.com/cgi-loca...lt&&1151359292
jbird40 07-26-2006 08:24 PM
Re: 30 outlaw
I saw the hand held GPS on a 30 OL with 496 HO's at the Lake travis Poker Run this year and it said 81 MPH.
It was smoking. They had a borrowed set of props from Hawkeye Marine that were pretty trick.
As for 525's, check out the following pictures. This was the first one built with 525's.
There was recently one delivered to Tennessee with 600's and I here it is a hand full.
The TN boat w/ 600s is the real deal ! 94 GPS and we are still dialing her in!
Sydwayz 07-02-2007 05:25 AM
I am helping a friend dial in his brand new 30 Outlaw with 496HOs.
Where is the ideal drive trim setting for cruise?
Where is the ideal drive trim setting for top speed?
How far do you guys trim in for turning? (What setting on the indicator?)
Do you ever have/need to run tabs, or do you leave them at neutral at all times?
I can figure all of this out with some seat time, but if I could get some info to start with, it will save us some time.
Thanks a bunch.
Sydwayz 07-02-2007 11:09 PM
Thanks a bunch.
Help please. :D
Busta 07-05-2007 02:42 PM
Originally Posted by Sydwayz (Post 2185483)
Help please. :D
Cruise - I usually set the trim on 2, tabs neutral around 5. 3200-3500 rpms yields about 50mph
Top speed - really depends but I believe I usually trim around 6 or 7, tabs up a little bit from neutral
Turns - same as cruise above
Tabs - mine are usually at neutral and mainly use them to level the bow for uneven loads or wind conditions.
My numbers may be slightly different because my boat is 2004 and I've heard that in 2005, Baja lowered the X dimension 1". Just for reference, I'm running stock Bravo 4 Blade 28's and HO's.
hangem out 2dry 07-25-2007 09:18 PM
I also heard that the x dem on the 05 is lower than an 04.I have an 04 with ho's that I am fixing to post in the classified section only 32 hrs for 105k mint condition been in storage 2yrs.
