Timing ?? >
Timing ??
Timing ??
Old 06-17-2006 | 05:50 PM
duksrule's Avatar
Registered User
Default Timing ??
I have a 502 mag fuel injected. Does anyone know the wires that need to be jumpered out in the data plug to set the timing?
duksrule is offline
Old 06-19-2006 | 01:04 PM
duksrule's Avatar
Registered User
Default Re: Timing ??
So does no one time their own boat or does everyone have the little plug so you don't have to use a jumper wire?
duksrule is offline
Old 06-19-2006 | 02:55 PM
Dock Holiday's Avatar
Charter Member #34
I have it written down at home. Will look tonight for you. Personally I use a scan tool that puts it in service mode.
If you ask this question over at Q & A you will get an answer quicker.
Dock Holiday is offline
Old 06-19-2006 | 03:08 PM
it's the a/b terminals. you'll have to bump up the idle a little or it will die.
kennyo is offline
Old 06-19-2006 | 03:10 PM
Charter Member #34
That is correct. Usually bump the idle up to 1500 to 1800 RPM.
Old 06-20-2006 | 10:09 AM
JasonSmith's Avatar
It is the a/b terminals. I have mine set at 10*
JasonSmith is offline
Old 06-20-2006 | 10:53 AM
Blewbyyou's Avatar
Dock,
how do you bump up the idle on the 502? (MPI) My brother has the 502 in a 98 24OL and it idles at 1000 to 1100, and he wants to drop it down a little.
Blewbyyou is offline
Old 06-20-2006 | 11:06 AM
Charter Member #34
Originally Posted by Blewbyyou
Dock,
What I was referring to in the above thread was simply advancing the throttles to a higher RPM.
To drop the RPM you would have to get your ECM's reprogrammed, assuming all the linkage is adjusted correctly and that is not what is making it so high to start with.
articfriends
13
01-07-2009 03:00 AM
tomas_wallin
7
05-26-2005 02:06 AM
ROLNTHUNDER
4
04-18-2004 06:36 PM
trobertsuk
5
03-09-2004 06:22 PM
34scarab
9
10-23-2003 10:20 AM
