Poll 29OL v 292 Formula >
Old 09-10-2007 | 07:54 PM
  #61
Full Force's Avatar
One big reason I went with a 32 foot boat was to get a better ride, way better then my 24 footer!
you should see some of these guys try to run cats on Erie!
Full Force is offline
Old 09-11-2007 | 06:41 AM
  #62
Erie is a beast that is forsure! That is why I am looking to go bigger. Although I have made my way to the islands from Toledo several times.
I have never seen them side by side but by pictures, isn't the 29 ol a lot bigger than the 292?
danh63 is offline
Old 09-11-2007 | 07:21 AM
  #63
sounds like every boat maker has their problems
http://www.speedwake.com/upload/show...threadid=21489
danh63 is offline
  #64
haulinvols's Avatar
www.Bajaboatowners.com
I have seen them side by side and driven both. The 29 Outlaw is much bigger physicaly than the 292. The 29 is s true 29 foot boat plus the add on swim platform. The 292 is closer to a 27 foot running surface with the integral swim platform. The Outlaw has a larger cabin as well as a much deeper freeboard.
As with any of these comparison threads, for the most part it is just opinion banter thrown back and forth. The only way to tell which boat is the best for you is to drive them and find out for yourself.
haulinvols is offline
Old 09-11-2007 | 11:29 AM
  #65
AIR TIME's Avatar
Originally Posted by 245 limited
I do have to say that we run my friends 353 pretty hard all summer, does 97 and has not fallen apart yet! ran the last poker run in 4-5 footers at 93-95 MPH most of the time running a 36 Apache! we are Lake Erie and if you have ever heard, it is not exactly a calm lake, worse ride then the ocean I am told by many due to the shallow waters and chop, when it is 6 footers here they are 6 ft high and 6 ft apart, makes for a rough ride.
I have had my 320 Baja for a week and already the bolsters are pulling out of the floor!
THATS BECAUSE ITS A 86 ,A LOT OF BOATS MADE IN THE 80s were screwed in to the floor which will pull out over 20yrs.plus they only used about 4 to 6 screws per seat back then and bolted the side to the gunnel which a lot of companies do to day which sucks. my new race bolsters have 20 screws or bolts which ever you want to use. you can pull the middle floor up unscrew it and put a star nut so you will be bolting the seat down or glass a 2x4 over the old holes then when you put the longer lag bolts in the seat is going no wear. if you want to read about floor replacement, stringer , bulkhead just look at jons in the Q A FORUM I brought it to the top you can see what I have been talking about pulling the mid floor up then glass the wood covered in glass hope that helps. I have owned mine for 17yrs. art
AIR TIME is offline
Old 09-11-2007 | 11:43 AM
  #66
AIR TIME's Avatar
Originally Posted by five cent worth
Doesn't even compare to anything out there. By far the roughest, especially on the south side.
By 245 did awesome in it for the year I had it up there though!
sounds like BUZZARDS BAY we have the ocean coming straight in with sw winds it goes from deep water out at the mv 100s of ft to like 50ft we get real 4 to 6s 8 to 10s standing straight up it funnels down to the cape cod canal like a sugar cone goes from 5 miles across to 300ft at the cannal no swells there swells you go to cape cod bay snot MV, nantucket sounds They cannceled the offshore races in 04 here and in 02 boats were smash up and sinking yellow fountian race boat.
AIR TIME is offline
Old 09-11-2007 | 04:38 PM
  #67
Full Force's Avatar
I know its old, thats one reason, I plan to cut the floor and back it up from under to fix it.
Thanks, Tim
Old 09-11-2007 | 10:55 PM
  #68
AIR TIME's Avatar
Thanks, Tim
you should be able to un screw the mid section. if your seats are tied in to the solid part of the floor just cut a 6''hole under the seat dig out some foam and then you can use a backer plate or glass a 2x4 in place. also drill out the old holes fill with filler and glass redrill unless your floor is soft. after the 6'' hole is done you can glass it back if you went with the 2x4 if not you need to just install 2 excess white plates you know what I mean the round ones that unscrew. thats a easy way if the floors are good with 20 mounting holes in my race bolsters they aren't moving even if I AM RACING AGAIN COMING OFF A 10 WAVE like at the cape race when we made the move for 2nd place and brused my navs ribs oh well. art
AIR TIME is offline
formula271
07-20-2010 03:08 PM
STUCK
12-21-2006 10:16 AM
ken
1
09-20-2005 08:37 AM
ken
09-18-2005 08:10 PM
Artman
09-08-2003 10:19 PM
