Rebirth of a Baja >
Rebirth of a Baja
Rebirth of a Baja
Old 04-05-2009 | 05:41 PM
  #641
Dock Holiday's Avatar
Charter Member #34
4400 RPM
62 MPH GPS and climbing fast
1 PSI Boost
Dock Holiday is offline
Old 04-05-2009 | 05:44 PM
  #642
Charter Member #34
5000 RPM
72 MPH GPS and climbing
Between 2 and 3 PSI Boost
Old 04-05-2009 | 05:47 PM
  #643
Charter Member #34
5300 RPM
Hitting 80 MPG GPS & Climbing fast
3.5 to 4 PSI Boost
Old 04-05-2009 | 05:51 PM
  #644
Charter Member #34
5400 RPM
82 MPH GPS and climbing fast
Between 4 & 5 PSI boost on the gauge
Old 04-05-2009 | 05:53 PM
  #645
Charter Member #34
Mostly just cruised at 3200 to 3500 RPM and still breaking everything in gently.
Question for everyone:
What to you perfer to seal up you fittings in the water lines?
Teflon Tape
Pipe dope
Old 04-05-2009 | 06:30 PM
  #646
Charter Member #34
I cannot wait to get the new props from Brett at BBlades.
If you run the calculations on different speeds and RPM's above the prop slip is off the charts.
According to Brett you need to consider the stock props a 31 pitch and not a 32 pitch.
I am also playing around with trim and never went more than two steps above neutral. Brett felt I was still trying to overtrim the drives. We'll see how the new props do.
Old 04-05-2009 | 06:42 PM
  #647
It looks like your hard work has paid off.
redbud35 is offline
Old 04-05-2009 | 06:49 PM
  #648
Charter Member #34
We're getting there buddy.
We have seen 88.1 GPS so far with the stock props. I will be very happy and satisifed when I see 93+ GPS.
I need some more break in time on the engines and drives and I need the new props.
How is your project coming?
Old 04-05-2009 | 07:00 PM
  #649
JasonSmith's Avatar
Teflon Tape
Pipe dope
Teflon tape. Pipe dope is too messy.
JasonSmith is offline
Old 04-05-2009 | 08:17 PM
  #650
Teflon Tape
Pipe dope
Typically we use teflon tape for the smaller dia pipe and pipe joint compound for the larger stuff (3/4"and above) and anything gas. Teflon tape is easier and less messy to use for the average joe.
Baja_man is offline
