Originally Posted by JasonSmith
(Post 2880759)
He would gain 3 inches if he went with -2" lowers & a Stellings box
True dat |
Originally Posted by JaayTeee
(Post 2880785)
True dat
I suppose he could go negative also. -2 lowers & box set at neutral would be a +2" gain upward in x or he could use -2" lowers with the box at -1" and net a +1" gain. Or use stock lowers & set the box at -1" and net a -1" deeper x. Or about any other combination. |
Originally Posted by AIR TIME
(Post 2880757)
no but you need a duel set and should go all the way to the helm.
Originally Posted by Baja_man
(Post 2880365)
I have been tagging along with you on this, don't mean to take anything away from the original posts.
It will be a winter projest as well for me. I do not want to raise the engine and repair fiberglass. I really do not have an opinion on either brand, just want the beneift of an ext box. My boat is at Wilson's Marine as we speak getting the trim sender and switched repaired and will get an estimate from Andy when I pick it up. Do any of these come with steering as standard equipment? |
Wayne
Steve(Violator) is going to be at St.Clair Run and he's running 12" IMCO with 496HO with CMI's running stock drive and running solid 70mph on gps full load. Too bad your not going to be there to check it out. My boat is up there right now as well I'm hoping he has it done on Monday so I can pick it up. |
(Post 2880759)
He would gain 3 inches if he went with -2" lowers & a Stellings box.:lolhit:
Mine are at 4.5" or so. |
Originally Posted by irishtornado
(Post 2880958)
Jason thanks for taking time to fill me in on what I'm looking at. It's always good to talk wioth someone who has experience in these projects.:drink:
(Post 2880788)
Bet cuz.
(Post 2881227)
I was only trying to help you since I have done these sets ups on my boat and others when my buddy OWNED a baja dealership a few yrs back, there have been guys who used a stelling box with the imco tork shaft, but I think theres a extra chit you have to do. that ujoint set up on stellings eats them drives well you will hear it when you put the drives in gear and out:eek:. good luck
(Post 2881478)
I appreciate your input. I'm leaning towards IMCO boxes and -2 Shorties. I'm looking to gain ride not necessarily speed with this setup. I'm hoping not to loose speed, but improve my ride and time to get on plane.
2 of my friends have older (98' and 00') 36 O/L's with Stellings boxes, and the drives aren't mounted that high compared to mine,( guessing in the 5" range) but they come out of the hole effortlessly, where mine has a certain routine that has to be followed in order to come out of the hole. |
| All times are GMT -5. The time now is 04:08 AM. |
