Props 272 >
Props 272
Props 272
Old 03-19-2009 | 07:39 PM
Default yes you are right!
Originally Posted by emilsr
A buddy of mine has the same boat/engine combo as you and he actually likes the 24p Bravo I better than the 23p Mirage +. Although it took his rpm down from 5k+ to 4700 he says he picked up a few mph on top. His is a few years newer than yours; maybe they changed something on the boat's setup from year to year, I don't know.
In any case, if you're turning the 23p Mirage + at 5k rpm that's right where you need to be. If you go to a 25p Mirage + you'll need to have it labbed to pick up the rpm you lose by going to a higher pitched prop. Since you like the feel of the 3-blade prop this might be a good option for you.
If it was me I'd try the 23p Rev 4 just to see how you like it. I have one that I'm going to be trying out on my 26OL as soon as I get on the water this year. Everyone I know that is running that prop on a Baja is happy with the results. As Bajaman mentioned, bblades has a prop loaner program but in Miami you should be able to find someone local with the same sort of program. They also may have some suggestions for you.
hello, yes i think that you are completely right about the rev 4 23, what i found in my research is THAT THE OLDER BAJAS HAS A TOO DEEP PROP SHAFT( 8 INCHES) AND THE BRAVO ONE IS A SEMI SURFACE PROP THAT WORK WELL ON MORE HIGHER PROP SHAFT CONFIGUARTIONS (i n my boat i feel too much drag), NEW MODELS COME IN 6 INCHES, IS BECAUSE THE BRAVO ONE WORK WELL ,BUT IN MY CASE THAT I INSTALL THE NEW ENGINE IN THE ORIGINAL SETUP IS GONNA WORK WELL WHIT A MIRAGE THAT GIVE A EXTRA BOW LIFT LIKE THE REV 4 BUT I CANT FIND ONE TO TRY. ANOTHER OPTION IS A HYDROMOTIVE INTIVIDATOR Q4 "X" WICH IS A NEW MODEL JUST DEVELOP FOR THIS CAN OF CONSERVATIVE X DIMENSIONS. CAN I ASKYOU HOW MANY INCHES DO YOU HAVE IN YOUR BAJA FROM THE KELL TO THE PROP SHAFT???
DO YOU KNOW WHO IS SELLIN A REV 4 23 P??? THANKS ALOT
THE BEST OPTION: INSTAL A IMCO SHORTIE LOWER....(2" SHORTER) WHICH I CANT AFFORD RIGHT NOW.....
REGARDS
DAVOR KANTOLIC
MIAMI/BAJA is offline
Old 03-19-2009 | 08:03 PM
REGARDS
DAVOR KANTOLIC
The distance from keel (actually a pad on our boat) to propshaft is 6 1/4 inches...I measured it so I'd know. We've only put 30 hours on it so far so I haven't tried any props other than the 23p Mirage + but I have several to try this spring including an older model Q IV and a Rev 4. Another prop you might consider is a Turbo Vector. That's a fast prop on the 272; might also work on your boat.
emilsr is offline
Old 04-14-2009 | 08:06 PM
Rrice's Avatar
Have a 272 502 built to a 500 hp merc race specs 542 dino. 850 holley running a 26 bravo 4 blade labed xr 1.50. extended tabs to 15" jumps out of the water dont need to trim. runs 74 Almost fast enough. LOL (never)
Rrice is offline
Old 05-15-2009 | 09:29 AM
For my boat, 1994 Baja 272 powered by a 330hp 454. It has a factory Mirage 21P, any advice on changing props for the current motor setup? Or is this about the best it will be?
Thanks!
SmurfOnABoat is offline
Old 05-15-2009 | 11:47 AM
obnoxus's Avatar
Charter Member #1171
21 Mirage Plus might be a bit better,,,, but thats about the best prop for that setup.
Alot are saying 4 blades,,,, but I think the drive is to deep on that boat to run a 4 blade
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-15-2009 | 12:41 PM
Whats the diff. between the Plus and Non-plus prop?
Old 05-27-2009 | 04:02 PM
The plus has more cup. I have double the cupping on mine for more bow lift. You can trim higher without the prop blowing out. You can have your current prob lab finnished and have more cup added.
jeffswav is offline
joker9r
06-03-2008 01:25 PM
morgansrun
Baja
5
06-15-2007 07:33 PM
HOTTZU98
3
05-13-2005 07:43 AM
boomer
08-06-2003 06:27 PM
dougB
0
05-06-2003 04:16 AM
