WTF is there so much hook in bottom for? >
Old 08-30-2009 | 09:50 PM
  #41
Originally Posted by Full Force
Going to Kevin? if so... good choice!
He did work for me, very happy!
Yea I am...I'm hoping he can pick me up a few MPH as well as improve the ride. I also have a few gel issues to fix and no better time than when it's there.
Irishtornado is offline
Old 08-30-2009 | 09:55 PM
  #42
Originally Posted by obnoxus
running 3 blades or 4 blades,,,,, 4's should do the trick
customer has a 302 he hates with 3 blade mirages on it,,,,, lent him my 4 blade labbed bravo 1's,,,,, he came back wanting to lend me his girlfriend in thanks !!!!!!!
The 03 29OL is running 28p Bravo's and can only spin them 4600rpms and when he trims up the boat is really squirrelly...
Old 08-30-2009 | 10:03 PM
  #43
Full Force's Avatar
He is very good, he also knows Baja very well too, never heard a bad thing and he did great work on my nightmare!!
Full Force is offline
Old 08-31-2009 | 06:16 PM
  #44
bowtye8's Avatar
Irish- Are they labbed 28's. I was running 26's on my 29ol. I wanted to try some labbed 28's. I was hitting 5-51k with my 26's.
I was looking to get a few more mph and keep the r's up with hte labbed 28. Sold the boat before I was able to test. I would trim the heck out of my 29 as well for max speed.
bowtye8 is offline
Old 08-31-2009 | 10:05 PM
  #45
Originally Posted by jeffswav
Get a double cup on the prop. Also if you get the boat going faster it will lift out of the water and the wedges will be out of the water. Mine free's up after about 62.
Thanks for the info. Yeah, mine does free up as I get upwards towards 60ish but I would like to have more stable driving throughout the range of speed. So, I am sure I can get a good steer towards a decent prop. I think I have read that there is a prop specialist that frequents this forum. Any help appreciated.
Ptrk99 is offline
Old 09-02-2009 | 06:25 PM
  #46
Dave, I took a couple of pics. The hook dosen't look as big as in person but you get the idea. Mine also doesn't go all the way to the bottom of the V. Just right in front of the tabs.
Attached Thumbnails WTF is there so much hook in bottom for?-img_0461.jpg   WTF is there so much hook in bottom for?-img_0462.jpg
indywhsle is offline
Old 09-02-2009 | 07:05 PM
  #47
JasonSmith's Avatar
You guys are wasting money taking that hook out. I do not believe it will make the difference you think it will. I do think that at best it will give you 1 mph up top, if it does that.
The best thing to do is run with your tabs in the water. I run with mine a touch negative along with the drives in neutral trim position for 99% of my cruising.
When it gets rough, drop the drives & when it gets really rough kick in some more tab. These hulls need negative tab input!
You can adjust the ride of the boat by moving more weight forward. especially in a 302. They are ass heavy to begin with & that is what makes them ride nose high. They are not balanced correctly.
By balancing the boat correctly you will run faster, more comfortable & more level.
For guys like Indy & myself, taking that hook out will do nothing. Our boats at speed run with that portion of the bottom out of the water, for the most part.
Don't believe me? Here is my boat at 90+ at the LOTO Shootout this past week & another from Lake Perry 2 years ago . Flat & fast.
Attached Thumbnails WTF is there so much hook in bottom for?-6573_137162824024_589394024_2281765_1391438_n.jpg   WTF is there so much hook in bottom for?-4498_1165714741977_1201158200_1477254_7196052_n.jpg
JasonSmith is offline
Old 09-02-2009 | 08:12 PM
  #48
Thats what I keep telling people. As your boat increases in speed the hooks (wedges) get out of the water and have not effect. My boat with a single free's up at about 62. You may have to get a boat with twins much faster. Spend your money on HP and the setup.
jeffswav is offline
Old 09-02-2009 | 10:03 PM
  #49
Here's mine running at Cumberland last summer and Lake St.Clair...Runs flat, but porpoises like a MO FO! I do run slight negative trim basically where the tab touches a level on the bottom of the boat and the trim about 3-4 clicks up...Now maybe putting boxes and shorties will help I don't know..I'm going to go for it and see where it takes me..
Old 09-03-2009 | 09:06 AM
  #50
JasonSmith's Avatar
If it porposises, trim the drives down. My 29 never has taken much trim to get it running fast.
From the looks of the pictures, you have the drives trimmed up a good ways, but it is hard to tell without driving it.
