Stellings box on 25 OL questions.... >
Old 04-26-2010 | 05:01 PM
Originally Posted by Baja_man
I have only heard of one incident where it set off the knock sensors. I know of two other installs, both on 25 OL that had no issues one was from the factory though who knows what they did.
You may get lucky and not have to.
I wouldn't put much faith in that the factory did anything special......I'm
pretty certain they installed both of my driveshafts out of phase
Last fall.
A guy rafted up with us that had just bought a 302
w/ HO's and Stellings boxes, he was complaining of
the lack of performance of it, we took a ride and
as I recall, the thing only ran 68-69 mph.
I told him about Keiths problem, havent seen
him yet this year to find out if he did anything
about it, but a 302 w/HO's will definetely run
better than what this boat was doing, so I'd
bet $$$ that he was having the knock sensor issue.
I hope you do luck out on this, because I'm
thinking that whipple is the only one that does
it, and they get 8 or 9 hundred $$ to do so.
Something else that I just ran across in the latest
merc manual I just got, is that on the units equipped
with jackshafts, ( like the forward engine in a staggered
installation) they are recommending that you phase
the U-joint on the driveshaft end with the u-joint on
the outdrive input shaft.
I never gave it much thought, since their 2 seperate shafts,
but, I'm going to set mine up this way.
JaayTeee is offline
Old 04-26-2010 | 05:55 PM
Any pics of this? I have very little knowledge of this sort of thing is why I take mine to a mechanic. But if there is something I can visualize or take a pic of it to him, it is easier for me to explain.
Thanks for the info.
Baja_man is offline
Old 04-26-2010 | 06:39 PM
Do you have the steering yet? I can help and save you money!!
violator is offline
Old 04-26-2010 | 08:55 PM
Yes, I do but am beginning to regret the direction I took. The box came with everything I need on the outside of the transom but I neglected to think of anything I need on the inside. So $1800 later I have full to the helm steering...not yet installed yet but have it. Lessons learned. I just hope IMCO makes a good product.
Baja_man is offline
Old 04-26-2010 | 09:15 PM
You will know if the knock sensor is retarding the timing when you take out the boat the first time after the installation - if you have somebody hook up a scan tool it will show the knock sensor tripping.
Keith Atlanta is offline
Old 04-27-2010 | 01:07 PM
Bottom picture on this page shows what I mean.
u-joint axis need to be parrellel
you'll want to try to line up the box driveshaft yoke
with the outdrive input shaft yoke
http://jniolon.clubfte.com/driveline...nephasing.html
JaayTeee is offline
Old 04-27-2010 | 04:25 PM
i have imco on my boat . it help a lot .just make shore you bleed it good
bajabob is offline
Old 04-30-2010 | 10:04 PM
Im glad I saw this, I just put my stuff back together and did not think to make sure my yokes were in phase, is it really critical?
Baja man, you might want to think about putting a "Drive Saver" in the box or on you flywheel, if you haven't allready.
they are expensive but I have an extra if you want to buy, thanks Keith Atlanta
My Addiction is offline
Old 05-01-2010 | 08:57 AM
Originally Posted by My Addiction
Baja man, you might want to think about putting a "Drive Saver" in the box :
Tell me more about this.....I have not heard of it. Any pics as I would be really interested in one and he is starting to assemble everything now.
Baja_man is offline
Old 05-01-2010 | 09:15 PM
Here is my thread from a while back
http://www.offshoreonly.com/forums/d...ox-teague.html
I went out today and the boat seems to shift quieter, then I remember from last year without the Drive Saver. Last year I was scared that my next shift would be my last everytime. But I did have a worn gimbal bearing and a worn U-joint, that is all new now, and new carrier bearings as well.
