Road to 60mph in a Baja 232 Islander
How fast should my stock motor 232 go? Looking for cheap speed. I know I know, there is no cheap mph. It had a new 454 carb motor put in last fall. 21 mirage 50 mph at 4800 rpms gps I am not looking for a 100mph boat just a fun 60+ boat for a couple years. I have a couple other props to try 3 blade stainless one is a labbed 23 to 25 how much power will it take to turn that? New to this and just trying not to buy parts twice.
see below.he knows it all !!!!!!!
Is that a 330HP engine? If it is a replacement engine what specs was is built to? You should only be turning the engine in the 4600 RPM range. You should see about 55 MPH with a 21 mirage, your slip numbers are about 21% that is really high. Are you sure your tach is accurate? Are you trimmed up for max speed? Again there is no cheap HP, you will need 400HP or better to get 60MPH.
a buddy of mine just bought a 97 232 islander with a 502 with aoround 450 hp and it runs 71.6 mph on a handheld etrex gps it has a 25 pitch labbed prop but no markings on it to tell who made it and it also has a stern jack spacer in the outdrive
Originally Posted by DareDevil
(Post 3123356)
Originally Posted by jeffswav
(Post 3123459)
(Post 3123531)
You are really to much. Why would you tell a guy to run his engine at 5000 RPM when is not made for that. You really have issues. But we are all used to your off the wall comments and I do not really want to get into another pissing match with you.
(Post 3123548)
I said u know it all, so why are u angry ?!
BTW, here is the deal. a 330 /454 can turn 5K rpm easy..its just on where u turn it ..jumping wakes and rev it up will kill it ,,but on a reg run at 5 K no problem,,,so mister baja expert...what is it actually that u do ..work wise ?? are u a engine builder ??
I am not , but i am around a lot and just becasue merc back then sayd 4600 max ( because of warranty ) does not mean u goona blow it up at 5 K. Is lower rpm better 100% every engine would last longer on the low side then rev it to the max. But getting 10 MPH out of a boat just with props on a not real good hull with 330 HP at 4600 rpm is imposible ! Later |
| All times are GMT -5. The time now is 05:19 PM. |
