almost there! 29ol/302 or 33ol? factors listed! >
Old 12-11-2012 | 02:38 PM
  #101
Anything will pull anyting....(hence the wonderful Toyota commercial where it is pulling the Space Shuttle)...it's control, braking and "what if something happens" due to someone else in front of you or around you etc...can you control your load with a 1/2 ton? Casual towing point A to point B I would say sure... But for "towing" anything 29/302 + I'd go 3/4 ton. Why? Less wear and tear on your vehicle, more control..less "pucker factor". But eveyone is a backseat driver when it comes to suggestions so take mine for what it's worth. My x-father in law's 29 on the scales went 10,800 with gear and fuel in it. I have never weighed mine but it is what it is. I did put my current 29 on the back of my current father in law's new 1/2 Ram and it put the wheels in the wheel wells on the back...again..."it is what it is". I do know for a fact in the hill contry around Austin etc. I would not ever try and tow a 29 + with a 1/2 ton. I have been in to many situations where the 3/4 ton saved my hide where a 1/2 ton would have gotten me in trouble... Trust me...I have often weighed trading down to a 1/2 ton because I don't really need a 3/4 ton to drive 30 miles to work and back and the 29 is kept at the lake in a boat stall and they vallet me in the water with a tractor...but just knowing I can pull and go anywhere I want, when I want, cross country or wherever and not worry about anything but stupid trailer bearings and trailer tires then it's worth it to me.
Again...opinions are like a$$holes...everybody has one. All that matters is you are comfortable and if something brakes you can fix it.
Good luck in your quest and hope everything works out for you.... I too cannot wait to boat shop for real again and not just look every day.
Hoss.
HOSSMAN is offline
Old 12-11-2012 | 03:00 PM
  #102
Originally Posted by HOSSMAN
I do know for a fact in the hill contry around Austin etc. I would not ever try and tow a 29 + with a 1/2 ton. I have been in to many situations where the 3/4 ton saved my hide...
I was going to go ecoboost until I thought about backing down the ramp at Travis with the lake so low and my 25 pulling my F250 down the ramp. Since I am looking to upgrade as nailit is bigger boat and smaller truck made me go All I could think about was the wife and kids in the boat backing down the hill and not being able to stop!!!
T-RAV is offline
Old 12-11-2012 | 03:18 PM
  #103
That means you're backing up too fast and hitting the brakes too hard. I keep my 24 about 2 miles from mansfield and tote it over there with a chevy trailblazer. All other aspects of towing aside, just backing down the ramp is not a big deal. If I let too much speed build up it's easy to lock the brakes up and slide backward. But it's also very easy to go slow enough to completely avoid that.
Crossett is offline
Old 12-11-2012 | 03:19 PM
  #104
had a buddy swwap a f250 for a eco boost. theya r ****... and the advertised mpg is BS too
class action law suit in the works kind of bull ****.
mittens is offline
Old 12-11-2012 | 03:48 PM
  #105
If you go any slower you would be stopped! It wouldnt slide a bunch just a little, when you go from brakes to really hard brakes! I use the ramp at Lago Vista, its super steep!!
Ask this guy!!!!!
T-RAV is offline
Old 12-11-2012 | 04:25 PM
  #106
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
Not apples to apples, but my daily driver is a Lincoln MKT with Ecoboost. Weighs about the same as an F150. I average 19.x combined. Not too bad for almost 400 HP and torque. I don't tow with it but I do have a heavy right foot.
Baja_342 is offline
Old 12-11-2012 | 06:12 PM
  #107
This was Travis (Lakeway) a year ago last Summer when it was down only roughly 40'....and it is lower. The launch ramp was posted and said "use at your own risk" at that time as it was broken....No 1/2 ton would have worked on this ramp.
Attached Thumbnails almost there! 29ol/302 or 33ol? factors listed!-miss-keli-backing-trailer-travis-2011.jpg   almost there! 29ol/302 or 33ol? factors listed!-miss-keli-backing-trailer-travis-2011-2-crack.jpg
HOSSMAN is offline
Old 12-11-2012 | 06:57 PM
  #108
Damn, that's a ramp!!!!
nailit is online now
Old 12-11-2012 | 07:30 PM
  #109
And I think Miss Keli backed the truck and trailer down the ramp !!!!
violator is offline
Old 12-11-2012 | 08:04 PM
  #110
Nightlife1970's Avatar
I know this is getting way off subject but I have to post it.
We get all crazy about towing. I don't know when they started to put ratings on trucks. All I know is we used to pull some heavy stuff on the farm with nothing more than a 1/2 ton Chevy. I'm talking a very heavy steel trailer, with a Bobcat, and several evergreens and tree's. I would not be suprised if that load was 25,000 pounds. Did you know you were pulling something sure you did. Would it stop on a dime no it would not. We are talking about a 1986 1/2 ton Chevy with a 350 that had what 200 Hp.
Certainly having a bigger truck is better, but we get all crazy like these trucks can't handle a 10,000 lb boat. Like it will mess the truck up, ruin the tranny.
Nightlife1970 is offline
