Phil'R Up 2001 Baja 25 Outlaw
#32
Installing a 7 blade RV wire harness, Battery in the tool box, LED Marker lights, LED Stop & Turn Lights, LED ID bar with 8 Backup LED's, 2 Dual usb ports, & upgrading the audio.
[RV wire harness doesn't have the same color wires.. talk about confusing wire connections]
[/IMG]
[IMG]
[/IMG]
[/IMG][IMG]
[/IMG]
#38
Nice! Sure wish I had a garage I could work on my boat, looks like everything is coming along well!
Question though on your gauges, I had my boat mechanic change my gauges out over the winter, and went to run boat this past Saturday and now my ignition alarm doesn't beep when I turn key to start, and my depth gauge was beeping. You think he hooked it up wrong or forget to reconnect something for ignition alarm?
#39
It's hard to tell without tracing wires back. I'd bring to him and ask him to check it out. Or get a multi-meter and trace wires yourself to see if there are any breaks or shorts in the wire.
