Baja Speed Survey >
Baja Speed Survey
Baja Speed Survey
Old 12-23-2002 | 06:16 PM
Ric232
Default Baja Speed Survey
Please post:
1. Year and model of boat
2. Engine & Horsepower (@ prop)
3. Top speed and RPM's at WOT (GPS or radar speeds only please).
4. Prop & outdrive gear ratio
5. Any mods to engine or prop?
I will try to compile a spreadsheet of the results including the above info and propeller efficiency. Please be truthful with your submissions. This is for information and not for egos. So, if your best run one way on the lake was 65 and 68 in the opposite direction, don't post 68. Post the avg of 66.5.
Thanks,
Old 12-23-2002 | 06:30 PM
1. 98 29 outlaw sst
2. hp500's, 470x2 pshp
3. avg. top speed: 82@ 5100 rpm
4. 30p bravo 1, 1.50 reduction
5. lab finished props
JaayTeee is offline
Old 12-23-2002 | 06:58 PM
Ric232
Also, be sure to mention if you are at an altitude that might adversely affect your performance. So far, I don't see a problem with Iowa or Florida.
Old 12-23-2002 | 07:06 PM
1) 1990 210 Sport
2) Custom 496 700 HP @ prop
3) 97 MPH on gps regularly. 98 is best!!
4) 29 Spinelli 4 blade, 6200 RPM through 1.5 gears
5) Short Shaft Bravo drive, custom prop, highly modified engine!
Dad's boat
1) 1988 196 Sunsport
2) Custom 357" 425 HP @ prop
3) 82 MPH (86 on the nitrous )
4) 26" Spinelli 3 blade, 6000 RPM through 1.5 gears
(6500 RPM on nitrous)
5) Alpha SS drive, custom prop, highly modified engine!
WETTE VETTE is offline
Old 12-23-2002 | 08:16 PM
Allan4
98 24 Outlaw
509 ci 520 hp Dyno (is that 490 prop??). All sorts of mods.
1.50 B1, no mods
Cincy Oh, 550' altitude
75.7gps @ about 5400, but that was lucky
Norm is about 73 gps @ 5250
23 labbed Merc Rev 4
Old 12-23-2002 | 10:05 PM
liquid asset's Avatar
1999 25 outlaw
502 mag mpi
23'' mirage plus
K&N filter ( headers $ ecu on the way)
best speed at 400 ft. 68 @ 5100 avg 66 at 5000 @ 800ft.
1.5 ratio
Only had it for about 2 months, only 3 times out so far
liquid asset is offline
Old 12-23-2002 | 10:15 PM
bajadude's Avatar
1 99 '33 Outlaw
2 HP500's
3 Avg. top speed: 74@ 5100 rpm
4 24P B1s, 1.50 reduction
5 All stock
bajadude is offline
Old 12-24-2002 | 08:29 AM
1. 2001 29 Outlaw
2. 496HO X 2 (850hp @ prop)
3. 78.3 mph GPS @ 5100rpm
4. 27 X 3 Mirage Plus w/1.5
5. Bronson Hill labbing
29 OUTLAW is offline
Old 12-24-2002 | 09:12 AM
garshev's Avatar
Question
29 Outlaw,
Could you tell me what kind of speed increases or decreases you experienced with you labbed props and how did they treat you at bronson hill??
garshev
garshev is offline
Old 12-24-2002 | 09:36 AM
1. 1992 240 Islander
2. Single 502 Mag NA, 385 hp
3. 68 mph GPS @ 5200 rpm
4. 21 pitch Mirage (not Mirage +), 1.36 Bravo 1
5. No engine mods
Holy Smokes is offline
