Baja Speed Survey >
Baja Speed Survey
Baja Speed Survey
Old 12-24-2002 | 09:38 AM
Originally posted by garshev
29 Outlaw,
Could you tell me what kind of speed increases or decreases you experienced with you labbed props and how did they treat you at bronson hill??
garshev
The boat came with 25 x 3 blade Mirage Plus. I didn’t have a GPS back then so I can’t compare their speed with my current 27’s in terms of GPS, however speedo with the 25’s would read 77mph and now the speedo with the 27’s reads 79-80mph all at 5100rpm.
When I called Bronson Hill about getting some new props they first talked me into trying 26 x 4 blade despite my objections. When I tested the labbed 26’s I was still turning 5100rpm but saw my speedo speed drop to about 74-75mph. I ended up getting the labbed 27 x 3 that I wanted all along. Speedo speed with these props is 79-80mph compared to 77mph with the 25’s.
My only complaint with Bronson Hill is that they wanted to tell me “what I need” vs. me telling them “what I want”.
29 OUTLAW is offline
Old 12-24-2002 | 10:49 AM
obnoxus's Avatar
Charter Member #1171
1997 272 after installing 502MPI on rev limiter with labbed 23 Mirage Plus 74 MPH ( with no hatch or backseat and no fuel so it really doesnt count )
I normally see 70 MPH @ 5100
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-24-2002 | 11:13 AM
Advantage's Avatar
Great topic guys!
1. 1999 29 Outlaw
2. 454Mags X 2 (770hp @ prop)
3. 75 mph GPS @ 5100rpm (all day long)
4. 25 X 3 Mirage Plus w/1.5 (Repitched to 26)
5. York Labbed Props, Raised X-dimension 1 1/2", modified flame arrestor
Advantage is offline
Old 12-24-2002 | 02:25 PM
baja bailey's Avatar
1999 Baja H2X
502 mag mpi (stock) except for Whipple flame arrestor
75 mph (gps)
25 pitch Mirage Plus
slightly raised x dimension
baja bailey is offline
Old 12-24-2002 | 05:35 PM
DTH
1998 29 Outlaw
Old 12-24-2002 | 08:07 PM
CigBoat's Avatar
1 1996 240 Sport
2 454
3 70 on speedo
4 23 mirage plus repitched to 24ish
5 I have Stainless Marine Exaust, nose cone, drive shower, gaffrig flame arrestor
CigBoat is offline
Old 12-24-2002 | 08:42 PM
boat#1
1. 1994 Bandit II
2. 454 mag
3. 74 on speedo
4. turbo 21 3bl.
5. bone stock
boat#2
1. 1998 H2X
2. fresh 7.4MPI
3. don't know haven't had in the water yet
4. Mirage+ 23 worked over by Darin
5. bone stock
pwam1 is offline
Old 12-25-2002 | 10:13 AM
DTH
woops, 1998 29 outlaw, twin 454 carbs, 66.5 anytime on gps, 23 mirage plus, stock
Old 12-27-2002 | 01:22 PM
Smitty's Avatar
Interesting Numbers!!!
1995 24 Outlaw
454 Mag Whipplecharged 6 psi boost (motor is all stock)
74.7 at 5000 rpm
26 Bravo 1 & 1.5 ratio
Prop is labbed.
Changing to roller cam setup this winter so I can hit 80 mph otherwise this boat will be for sale!!!
Smitty is offline
Old 12-27-2002 | 03:12 PM
jdnca1's Avatar
Old Boat
1993 Baja Bandit II
502 Magnum est 625HP
80 on the gun
26 spinneli 4 blade; 1.5:1
Solid roller cam, roller rockers, full port, 2.25 intake valves with 3 angle job, dart intake 1050 dominator. Stock CR, Stock bottom end.
jdnca1 is offline
