Baja Speed Survey >
Baja Speed Survey
Baja Speed Survey
Old 12-28-2002 | 03:05 AM
fast 252
1998 252 468 ci 680 hp blower, with extention box 2" rised x bravo 1 30p 85 mph
Old 12-31-2002 | 12:02 PM
dhoughto
Default Speed Survey
I am including the numbers for both of my old Bajas. I have a new 275 on the way.
96 Baja 232
300 hp 454
GPS 63 mph RPM's (I forget now but believe 4400)
Stock prop and gears (1.50 Bravo 1) 23 Mirage
No modifications
99 Baja 252
415 hp 502 MPI
68 GPS at 5050
Stock Bravo 1 with 23 Mirage (stock)
Corsa Q&Q2 with angled tips (not a perf mod)
Dave
Old 12-31-2002 | 12:47 PM
29Fever
1 1999 Boss302
2 7.4 mpi (2) 310hp
3 63.6 on GPS
4 23 mirage 1:5 Bravo HP (low water pickups)
5 no mods
Old 12-31-2002 | 12:57 PM
99Hammer
1999 Boss Hammer
7.4l MPI, 310 PSHP
65-66 on GPS(reads 75 on speedo), (full tank of fuel and 2 people)4900 on tach (I believe the tach is off, 4700 is supposed to be the rev limit setting)
23P Mirage plus not labbed, Bravo 1, 1.5 gears and low water p/u
only mod is a K@N filter
Old 12-31-2002 | 01:30 PM
BajaRunner's Avatar
1. Baja Force 265
2. 350 mags (2)
3. 64 GPS
4. 23p mirage (not plus) 1.5 both RH
5. Cams, otherwise stock
BajaRunner is offline
Old 12-31-2002 | 04:42 PM
Waterfoul's Avatar
Gone Fishin'
1987 Baja 24 Sport (Outlaw) Second one ever built (can you say heavy??)
468 ci. Chevy approx. 435 hp
64.8 on GPS with stock Merc. Bravo one 24" at 4900 rpm
62.4 GPS with stock Powertech 22" 4 blade at 5200 rpm
Lot's of little things done to the motor over the years. EMI Exhaust, cam work, mild port on the rect. heads, carb, etc...
x-dimension raised 2.5" over stock. Not sure if it added any speed but it improved handling.
Mike
Waterfoul is offline
Old 01-04-2003 | 10:18 PM
baja 272
2) 502 mag efi
3) 67.6 GPS
4) 23" labbed mirage plus
5) CMI elbow tops, K & N filter, also applied speedcoat
Old 01-05-2003 | 05:59 PM
liquid asset's Avatar
My gps in Brad Perry's hammer at 96.2, best run is 98
liquid asset is offline
Old 01-05-2003 | 09:06 PM
EWB
2000 H2X 502 250 powercharger 30p Bravo1 82.4 gps installing stellings standoff box this winter changing cam and heads and blueprinting the bottom.
EWB is offline
Old 01-06-2003 | 12:20 PM
BajaBoss252's Avatar
I guess I have the slowest Baja on the board, maybe the slowest one oever made
1. 1999 Baja Boss 252
2. 454 MAG MPI (385 HP)
3. Best GPS 62.1 MPH @ 4900 RPM
4. 23P Mirage plus (labbed) 1.5:1
5. K&N air filter, removed mufflers and went with open tips, Simrek drive shower
BajaBoss252 is offline
