where to put subs? >
where to put subs?
where to put subs?
Old 04-12-2004 | 08:09 PM
SSComp's Avatar
Originally posted by yzbert
do you mean firing toward the stern? how would they fire forward?
Low frequency sounds are non directional
SSComp is offline
Old 04-13-2004 | 06:29 AM
bikinilover's Avatar
Originally posted by Bust-a?
Nice install Bikinilover! It looks like you coated the boxes with some kind of sealer? What did you use? I've contimplated building a box for under the seat to improve the sound of my free-air but haven't had the time to tackle that one yet. The sub in my cabin does the job fine but it would never hurt to have a little more bass coming from the bench seat - the chicks seem to like it there! Do you get any unwanted rattles or vibrations from having the subs under the bench?
Thanks! They are coated with some sort of fiberglass sealer. No rattles, pretty solid install.
bikinilover is offline
Old 04-13-2004 | 10:39 AM
yzbert's Avatar
Pics using my old kickers:
bajalion has attached this image:
does that add good bass in the cockpit area?
yzbert is offline
Old 04-13-2004 | 11:01 AM
SSComp's Avatar
Frankly, I bought the boat this way.
I personally would not have done this type of mount on the on set.
I compared my 600 watt (300 each overrated) to some much larger systems. My system was much better.
The cabin acts as a huge bass chamber you can really feel. Any loose items (floor boards etc) will vibrate. I found myself chasing these vibrations. You can actually see the water ripple as you crank it up. This truly prooves its not the "size" of the systems that matters it's the "magic" of the intallation.
The absolute worst thing you can do is place the woofer in free air. Read the info on your speaker before you by it. Some react better in some enviroments than others.
If you do not want to do much cutting or fabricating then I suggest a band pass box. this would be resistant to environment issues yet still give the punch you need.
I attached the following cheapo pic. You could pict this up at best buy for about $70
SSComp is offline
t500hps
02-25-2007 05:01 PM
Nordicflame
Nordic
4
06-03-2005 01:57 PM
TOMMY HIWAVE
5
02-14-2004 11:01 PM
ThirdBird
07-27-2003 08:41 PM
