imco shortie >
imco shortie
imco shortie
Old 12-07-2004 | 06:06 PM
Dock Holiday's Avatar
Charter Member #34
Default Re: imco shortie
Originally Posted by baja36ft
Well, i just bought a set of imco shorties and going to try them if it don't work they will
be for sale.I will post the results!!!!!! right now i do 74.8 on gps.
Please give us some feedback. Will be much appreciated.
I have a buddy that put 850 HP per side in a 2001 Baja 36 Outlaw and added 2 inch shorter IMCO's at the same time so we did not know if just the drives would have made much difference.
His both pushed 32 pitch props to a best of 94 MPH on GPS. Was a very strong setup!
He did not have any problems with handling, getting on plane or with the props blowing out. The package worked very well.
Good luck
Dock Holiday is offline
Old 12-13-2004 | 06:36 PM
baja36ft's Avatar
Thanks DOCK, are you going to the new york poker run this year??
baja36ft is offline
Old 12-14-2004 | 07:23 PM
Charter Member #34
Maybe, we have thought about that one. We did 7 poker runs this year, three of which we want to go back to next year.
There are three that we are considering, New York, Thousand Islands and East Side.
Have you done the New York run? Looks kind of crazy with all the boats?
Old 12-15-2004 | 04:06 PM
baja36ft's Avatar
no we didn't do it but we were there i am from new jersey so i know the water pretty
good!!!! don't live there any more but i still like to go to that poker run.
baja36ft is offline
Old 12-29-2004 | 12:26 PM
AIRTIME
Anyone ttry a shortie on a 24ft outlaw ? I'm going with a 2''or3'' not sure I'm trying to get better handling out of mine chine walks over 70mph dosen't fly level I have 647hp and adding a procharger m3or 4
Old 01-04-2005 | 08:30 AM
baja36ft's Avatar
If you have a hook in the back of the boat the shorties won't work so check that before
anything!!!!
We are going out this weekend and testing the shorties on a 99 36 outlaw with 500's i will post the results!!!!!!!
baja36ft is offline
Old 01-08-2005 | 05:13 PM
baja36ft's Avatar
Here are the results on the 2 inch shortie put a set of 27 hydro's on could not get on plane
so changed the props to a set of 26 bravo's got on plane (it was real hard) but they sliped
a lot could only get 71 mph at 5350 rpm so we are putting a 1/2 spacer and try it again.
baja36ft is offline
Old 01-09-2005 | 09:35 AM
yzbert's Avatar
thanks
keep us posted
yzbert is offline
Old 01-09-2005 | 12:06 PM
baja36ft's Avatar
I sure will any thoughts let me know????
baja36ft is offline
Old 01-11-2005 | 03:42 PM
Charter Member #34
WOW, that is a real surprise. I am sorry to hear that. Cannot understand why my buddies boat did okay. I called him to confirm that his were 2 inch shorties, and they were.
I see that Drill It has big HP, as does my friend. Wonder how this factors in against the stock 500's?
Have you spoken to IMCO?
I really appreciate you posting on here the results. This will certainly help a lot of us.
Good luck!
