imco shortie
I tried 2inch shorter on a 32 a/t would not plain. I tried 1 inch spacers still sliped real bad. so i tried 2 inch ( back to stock) they worked. if you have problems plaining you can try my spacers. Im in powhatan VA. not fare from you. I was runing 800hp with 1:34 and 34 labs .(my wife is telling me my spelling sucks)
Originally Posted by AIRTIME
Anyone ttry a shortie on a 24ft outlaw ? I'm going with a 2''or3'' not sure I'm trying to get better handling out of mine chine walks over 70mph dosen't fly level I have 647hp and adding a procharger m3or 4
Very curious to see what a shortie will do on a 24. Anyone know?
I really would like to get a 1/2 spacer and see if that works i did get on plane with the bravo's but it was not easy so the 1/2 might be just right. i measured from the bottom
of the boat to the prop shaft and i am 4 1/4 so i thought that would work but i guess
not what is the price for the 1 inch spacers??
I can't understand it Dock but it's true and yes i did talk to imco they said my x may be
little higher than i thought. so i will keep at it. I don't think the power has any effect
on getting on plane but i could be wrong.
When I first went to the Imco 3 inch shorter lower, I was running a 30 pitch Bravo 4-blade labbed prop. I too had a hard time getting on plane. Even once I was up and running the prop was slipping a lot. I dropped the drive a 1/2" but that didn't help either. I then tried a Herring 5-blade and a 6-blade (which is what I am running) and I solved any slip problem. Getting on plane was no problem and the boat really was hooked up. At the time Mercury didn't have their 5-blade out. You may want to give that a try as it is a lot less expensive. The 6-blade Herring is 28 pitch.
Good luck.
Drill It
Good luck.
Drill It
I tried a 2" shortie on my 01 25 Outlaw and lost 3-4 mph. Actually got to plane much quicker but did not handle as well. It actually leaned to the outside of a turn (pretty agressive turn) and scared the chit out of me and my passenger. Took it off and went back to stock.
Drill It may have the right idea. Before I added a spacer I would call Julie at Throttle Up and have her to loan you some 5 blades to try.
I have seen the 5 blades work wonders on high "X" boats.
