Go Back  Offshoreonly.com > Owners Forum > Checkmate
Checkmate speeds >
Checkmate speeds
Checkmate speeds
Old 09-29-2008 | 10:37 AM
  #51
Keytime's Avatar
Originally Posted by nwimbush
Cool...pretty much the same as my '89. Do you have K=planes? Also, I'm interested in seeing the waterline when the boat is at rest, as I haven't had mine in the water, yet....busy building a garage for it this year while I get the engines ready.
I have the Bennett tabs on my boat. Figured I'd run 'em until they gave me any issues and then possibly upgrade to those Victory's. I was told LOTO will bend Bennett's. No problem yet in one season, but I'm probably being pretty nice to them.
Do you have K-planes?
Here's a shot of the boat at rest at LOTO over Memorial Day Weekend:
Keytime is offline
Old 09-29-2008 | 10:46 AM
  #52
Nice shot - not much water clearance to the pipes - do you run flappers? I picked up some Corsa mufflers which will stick out even further, so I think I'll haf to run flappers.
Yup - I have K-Planes that came with the boat, along with the Bravos - all untested by me yet - I can't post pics here anymore - you'll need to see http://forums.boatfreaks.org//vbgara...o=view&id=3610
nwimbush is offline
Old 09-29-2008 | 11:55 AM
  #53
Keytime's Avatar
Nice ride! Looks really clean. How much hp are you getting out of the motors now?
No flappers. I have the Corsa Quick-n-Quiet set-up and, FWIW, when I come off plane, I'll often switch the exhaust through the drives or I'll come off plane gradually to keep the water from rushing up into the pipes.
I'm having some fluid leak down the transom from my Bennett trim tabs. I need to look into that, too.
Keytime is offline
Old 09-29-2008 | 12:43 PM
  #54
socalstone's Avatar
What is the weight of a 25 Checkmate Convincor?
socalstone is offline
Old 09-29-2008 | 01:44 PM
  #55
Bought her without engines - building them in my spare time this year, so we should keep in touch...
PayCheck.
nwimbush is offline
Old 09-29-2008 | 02:02 PM
  #56
Keytime's Avatar
PayCheck.
Definitely. Keep me posted on your progress.
Keytime is offline
Old 09-29-2008 | 06:02 PM
  #57
My Boat is a 259 Convincor
-468 cid 8:1 compr
-FAST engine management with 60 lb/hr injectors
-Whipple making 3psi
-Mild hydraulic roller 224/236 @ .050 .594/.600 lift
-CMI sport tube lites
-Stainless valves in stock Mag heads with the bowls blended
-MSD distributor and 6AL
-Aermotive fuel pump and regulator with -8 supply
-Bravo 1 with Bravo 4 blade 28p reworked to a 27p
With just me on board and a full tank of fuel I get 75 MPH out of it on the GPS and it is turning 4900. I am gonna try a 26P 4 blade to try to get a lil closer to 80 mph with some more tuning.
EightSecv6 is offline
Old 09-29-2008 | 07:28 PM
  #58
socalstone's Avatar
-468 cid 8:1 compr
How much does a 259 convincor weigh?
What's your hp?
Old 09-30-2008 | 06:22 AM
  #59
RJBBC's Avatar
Registered User
[QUOTE=socalstone;2701149]How much does a 259 convincor weigh?
Around 4250lbs with a BBC and Bravo drive or so I am told.
RJBBC is offline
Old 10-01-2008 | 04:20 AM
  #60
What's your hp?
I believe about 4250 is right, I dont know how much power it makes, somewhere around 550 I would think????
