Go Back  Offshoreonly.com > Owners Forum > Checkmate
Checkmate speeds >
Checkmate speeds
Checkmate speeds
Old 10-20-2008 | 04:05 PM
  #81
Originally Posted by Keytime
What is this "notch"? Is it a step?
Is this the 107mph boat?
http://www.kunkelsmarine.com/newboats2.html
Yes that is the boat and it does not have that 540 in it like the add says. Its a old add it has been a while since they have updated their site.
PURPLE HORNET is offline
Old 10-28-2008 | 03:53 PM
  #82
AIR TIME's Avatar
Originally Posted by Old Navy
And the BS flag is going up the mast.....
hey I was told I was bs last time out for me 5800 to 6000rpm 83.2 gps in my ol thats about 12% slip with a 26 b1 that was balanced boat 4000lbs 70gals gas hit the rev. 1.50 gears. 670hp hope that helps. this spring 1050hp 572blown. any C Ms in mass cape area ,plymouth, fallriver we are trying to get local guys to do pokerruns or day and overnight trips to the islands for 09 well theres some nice speeds that you guys are getting thats good I would of bought a Cm but my friends family bought a baja dealership instead of a C M whats funny he still has a 17ft one AND iHAD A 14ft way back. artie
AIR TIME is offline
Old 10-28-2008 | 04:00 PM
  #83
AIR TIME's Avatar
Last run of the year: 73.1gps.
1999 28' Convincor
Twin stock 454 EFI Mags
Bravo 1's
27P Mirage Plus 3-blades
5100rpm
Rockin' back and forth. Gotta figure out how to settle it down w/o scrubbin' speed. I'm learning. Suggestions welcome! Not sure if I'm just trying to trim it up too much or my drives aren't at identical trim or ?????
full hydraulic steering or learn to countersteer real fast thats what I did while running in the 80s, I had add on steering now full.
AIR TIME is offline
Old 10-30-2008 | 11:20 AM
  #84
Keytime's Avatar
I have full hydraulic steering to the helm.
Keytime is offline
Old 11-07-2008 | 11:39 AM
  #85
Mr Gadgets's Avatar
Charter Member #601
1999 283 Convicer, 565" Imco stand off box, 27" labbed prop, all the junk out of the front, light on fuel, very light. 87.7mph GPS, with 5 bad cam lobes. One pass, didnt see the tach or have the datalogger running. Found myself in shallow water and had to back out of it. I suspect I was at 6300rpm, but dont know.
Was going to do some backup runs the next weekend and found the damaged lifters and cam lobes.
Mr Gadgets is offline
Old 11-08-2008 | 01:14 AM
  #86
Thats hard to belive with 5 bad cam lobes. That engine must have 1000 hp do do that with 5 bad lobes. I don't even see how you could keep it running with all that spitting and poping from 5 bad cam lobes.
Old 11-08-2008 | 04:28 AM
  #87
Vinny P's Avatar
I hate the winter!!
There are different stages of bad. You are right, a very worn cam lobe will make an engine pop and run bad. A mildly worn lobe will just cause you to loose a few thousands of lift and duration. I had the same issue myself , only 2 of mine were worn down a bit. I should have realized it , when I went to adjust the valves and found 2 that were .005" loose.
Vinny P is offline
Old 11-08-2008 | 06:59 PM
  #88
Mr Gadgets's Avatar
Charter Member #601
Looking at the data logs I find that I am using about 395 lbs of fuel per hour at WOT. Depending on BSHP that figures out at about 700+hp. And a couple of the lobes were worn by .015" over the nose, if I remember correctly. No poping or spitting.. ran nice. Just some rattling noise at idle..
I just wish I had not run over a stinkin weed bed that I didnt know was there. The lake was full of blow boats at the time. I should have realized why they were not in that area. I had only bumped the trim one time.. I really think it would have gone faster... but nobody was with me. Just the GPS tell tale, so I can prove nothing!! Just my word and the GPS that it did..
Old 11-11-2008 | 06:17 PM
  #89
ok not as big as u guys a little toy i got at a good price.......89, 20' with a evinrude 200...i know dont bust me to hard....full tank of fuel (30 gals) 4 people each at approx 150-170 no jack plate or anything with a 22pitch 3 blade raker i hit 60 on lake george in middle of october...any ideas on how i can get more speed with out slapping a jack plate on the back?
lakedog350 is offline
Old 12-14-2008 | 02:15 PM
  #90
Commander112's Avatar
Default My Old Checkmate
Use to have a 1996 Convincor 242 with a blown 540. Fastest it ever ran was at a radar run in Richmond, VA in 2002. With 15lbs of boost and 150hp NOS kit it ran 110.3 mph. Pics below is of the motor after it came out of the 242 and went into my cat. Sold the boat to some dude from OH in 2003. Bow-tie block, 9:1 JEs, custom Crane cam, AFR heads, Crower SS roller rockers, Whipple Inner-cooler, TBS 10-71, Nickerson carbs, and a whole lotta KE parts...
Attached Thumbnails Checkmate speeds-img_0040.jpg   Checkmate speeds-img_0375.jpg
Commander112 is offline
