Go Back  Offshoreonly.com > Owners Forum > Checkmate
speed with zt 260 >
speed with zt 260
speed with zt 260
Old 03-02-2010 | 10:16 AM
CAB
Originally Posted by noyzee
i was poking around for parts, but not much luck.
the porting would pick up big, i know what it does to big blocks we build for cars!!
Call Scott at Speed and Custom Marine in Quincy, FL. Phone number 850-875-0381. He has a 496 HO that was ran hot and blown up. Maybe some parts you can use. Tell him Craig gave you his number.
CAB is offline
Old 03-08-2010 | 01:19 PM
noyzee's Avatar
thanks for the info.
all i need is cam and computer?
noyzee is offline
Old 03-22-2010 | 02:05 PM
zt260's Avatar
My first engine in the ZT260 was a whippled 502 that made 760Hp on 93 octane and 800Hp on 110 octane. Top speed with 760Hp was 87mph and 90mph with 800HP. This was with a standard length mercury sportmaster 1.35 ratio and a bravo 26 pitch.
Hope that helps.
zt260 is offline
Old 01-10-2011 | 08:28 AM
CAB
No pictures yet. In the building process. Should be finished in about 5 or 6 weeks. Going with a 588 ci fuel injected tall deck, ITS gimble, xr drive with -2 sportmaster.
Been a while. Motor dynoed at 635hp/650ft lbs. torque. -2 shortie works well. 5000 rpms at 79 mph with 1.36 xr drive stock out of the box bravo 1 26. These numbers were disappointing due to cam selection mostly. So now M3 Procharger on the way.
CAB is offline
Old 04-11-2011 | 08:32 PM
CAB
First run with pro charger was 90 mph. Only made 2.5 lbs boost. Ordering new pulley to get it to 5lbs. Not a bad run for 2.5 lbs.
CAB is offline
Old 04-11-2011 | 11:06 PM
Nice! Gotta love the M3's!
offshorexcursion is online now
Old 04-12-2011 | 07:34 AM
boatn70's Avatar
Default find out the pulley measurement
i believe i have a procharger pulley that was good for 7psi on my m1 i had. i will have to look and measure it. if you can find out what measurement you need i will check mine. will let it go cheap!! it is a 12 rib pulley. i will check diameter also
you can email me at maurer70 at sbcglobal.net if youd like.
just an offer to help.....
boatn70 is offline
Old 04-12-2011 | 06:19 PM
Not bad is right!
Congrats on the new power.
HD
hotdaddy27 is offline
Old 04-13-2011 | 10:03 AM
noyzee's Avatar
wow, id be afraid to run 90 on my 26 zt. lol thats nuts, have to be perfectly calm day for sure!!!
noyzee is offline
Old 04-13-2011 | 05:23 PM
CAB
Was not bad. You have to drive it but it is not stupid. We will see with the 5lbs of boost.
CAB is offline
