Go Back  Offshoreonly.com > Owners Forum > Checkmate
Need help with my new boat please >
Old 05-31-2010 | 02:40 PM
Default Need help with my new boat please
Well, I just bought a 2000 checkmate 259 convincor and took it out for the 1st time this week end. Its got the 502 magnum 415hp motor and a mirage 25p 3 blade prop. I was very disappointed in the performance. Everytime you take off and its starts to plane off the prop slips/cavitates and you have to back the throttle down then get back into it. secondly its only pulling about 4300rpm to. It seams very slow from a dead stop. Is this a problem with the prop? what do you guys recommend? any help
mustang3414 is offline
Old 05-31-2010 | 07:01 PM
ENFORCER24's Avatar
4300 rpm is low for a 502 in that boat , switching to a 4 blade will end that blowing out and cavitation
i would say 25 pitch on a 3 blade and 24 on a 4 blade should get you more then 4300 on that boat , unless your luggin around some serious weight , do you have a gps to figure out what speed your going? also make sure your not dragging tabs , i'v had that cause the prop to blow out and will also limit your top end , are you getting it trimmed up and out of the water well?
ENFORCER24 is offline
Old 05-31-2010 | 07:07 PM
Guys please tell him that checkmates dont like bow lift props, they like stern lift props
fastscarab22 is offline
Old 05-31-2010 | 07:36 PM
Just 2 people in the boat and 1/2 tank of fuel. As soon as it starts planing off i'm trimming it up but the boat likes to porpose then. trim tabs are set out in the middle i found it to be the smoothest ride there. I got a 24 coming from a memeber that was nice enough to help me out and trade him for mine
Old 06-01-2010 | 12:21 AM
Keytime's Avatar
You made sure the trailer wasn't still attached, right?
Keytime is offline
Old 06-01-2010 | 11:07 AM
I called hydromotive and he told me his quad 4 x 23p will make it a totally different boat.
Old 06-01-2010 | 12:08 PM
noyzee's Avatar
my boat did the same with a 23p 3 blade. back to the 4 blade and perfect.
i might buy a hydro prop to try it out as well.
noyzee is offline
Old 06-02-2010 | 05:34 PM
Checkmates don't like bow lift props, they like stern lift props!!!
A 24p Bravo 1 or Hydromotive should do the trick. My boat likes the B1.
fireguy is offline
Old 06-03-2010 | 11:18 PM
I say a 22p Bravo 1 stock 4 blade on a 415 horse 253 I think a 24 might be a bit much.
PURPLE HORNET is offline
Old 06-04-2010 | 09:47 PM
SOX's Avatar
SOX
Semper Fi
I am running a 24p Bravo 1 with my 253 (454 mag 350 hp) Think a 22p would work better for me?
SOX is offline
