Top Gun Engine Location? >
Old 09-05-2005 | 03:01 PM
Default Top Gun Engine Location?
Engine locations in Top Guns?
Is a TRS boats engines higher and more forward?
The distance between transom and the firewall- Are they the same between TRS boat and other?
I am assuming the firewall is even further forward on stagard engine setup? Distances?
Thanks again
big-boss is offline
Old 09-05-2005 | 03:40 PM
BLee's Avatar
Charter Mod
Default Re: Top Gun Engine Location?
Thanks again
I don't know the exact measurements, but TRS boats do have their engines set further up to accomodate for the trannys. They were originally designed to run TRS drives. That's why some bravo Guns porpose.
BLee is offline
Old 09-05-2005 | 03:50 PM
The Menace's Avatar
Brandon you are right, however, there is more to it than that. Some guns built with Bravos porpoise.
The Menace is offline
Old 09-05-2005 | 04:46 PM
BLee's Avatar
Charter Mod
Yes the ones built on the TRS CG with bravos are the ones that porpose. They later changed the CG to fix the problem.
BLee is offline
Old 09-05-2005 | 05:51 PM
DirtyMoney's Avatar
What was changed to change the CG?
DirtyMoney is offline
Old 09-05-2005 | 07:30 PM
Another question:
The CG (center of gravity). Where is the CG on the boat? Where is it in relation with the cockpit? Is there a book with all this cool stuff in it?
big-boss is offline
Kool-Aid Man
Detailing, Painting, & Fiberglass
2
05-19-2008 05:37 PM
priceb
09-30-2007 09:14 AM
seahawk
Cigarette
21
06-15-2006 09:28 PM
big-boss
Cigarette
1
06-13-2005 09:25 AM
suncoastpower2
Cigarette
5
10-03-2004 08:21 PM
