need tips for replacing trim indicator cables >
Old 05-16-2007 | 11:01 PM
J-Bonz's Avatar
Just read through this thread and others that I searched. I am in the processs of replacing both indicater cables. How does the plastic faceplate come off? Is it held on by the four fasteners underneath located at the four corners? Since there is no way to get behind the dash of a straight bottom gun, Will the assembly come out of the hole that the trim/drive faceplate covers....? OR Will I have to bring it out from under the mane dash panel that wraps around the compus..?
Any ideas......... Suggestions..........
Jr.
Attached Thumbnails need tips for replacing trim indicator cables-directions.jpg
J-Bonz is offline
Old 05-17-2007 | 07:55 AM
Ted G's Avatar
The back portion is smaller than the front so if they cut it right you should be able to pull it up through the hole after removing the faceplate.
www.cbpba.com
Ted G is offline
Old 05-17-2007 | 08:02 AM
J-Bonz's Avatar
[QUOTE=insptech;2130819]The back portion is smaller than the front so if they cut it right you should be able to pull it up through the hole after removing the faceplate.[/QUOTE
......................... Then disconect old and replace with new?
Jr.
J-Bonz is offline
Old 05-17-2007 | 09:55 AM
Ted G's Avatar
Yeah, they are held by a bracket and the heads screw on the cable ends, it is pretty self explanitory when you get in there, watch for the springs in the pointers and the spacers on the bolts and you should be fine.
www.cbpba.com
Ted G is offline
Old 05-17-2007 | 10:28 AM
J-Bonz's Avatar
Cool, Thanks
Jr.
J-Bonz is offline
Old 05-17-2007 | 03:06 PM
offshoredrillin's Avatar
put a stick pin through them and use that to hold the top and spring in place, then when it is back together pull the pin out, in the diagram it's called an alignment wire. I just did mine on my tiger.
offshoredrillin is offline
Old 05-22-2007 | 09:58 AM
mjb
Thanks to BillR, all cable lengths for a Top Gun.
Cable lengths:
Trim Tab:
P-26
S-21
OutDrive:
P-25
S-24
Throttles:
P-24
S-22
Shift:
P-24
S-22
Might be good to jot these down for future reference.
FYI- I'm not sure where BILLR got these lengths but they are different from the stock cigarette cables in my '97 top gun. I pulled mine out this weekend and measured them...twice.
TABS- S-21"/ P-25"
OUTDRIVES- S-23"/ P-24"
I'm glad I didn't order my new ones yet!!
mjb is offline
Old 08-13-2007 | 08:45 AM
offthefront's Avatar
I need shift cables ... from the controls back to the motors ...do I have to get the standard bare end cables (10-32)? They Make a style with the Merc ends on one end and a 10-32 on the other ... The controls Are "k" and have the hook that attaches to the control ... I am at work today and cant look at them and need to order .... thanks ...m
33,35 or 30 Series ... I know the 33 will work but would be nice to have the new ends .....
File Type: pdf
offthefront is offline
GoFastSonic
Sonic
4
08-05-2008 10:52 AM
powerquest280
Sonic
6
04-14-2008 08:03 AM
PARADOX
3
08-28-2007 10:55 AM
blown formula
05-07-2002 03:37 PM
blown formula
4
05-06-2002 09:27 PM
