Top Gun Electrical Problems >
Old 10-20-2008 | 01:47 PM
thisistank's Avatar
Originally Posted by chewy1955
Thanks SEAFORDGUY. Any wiring info will help. I haven't been able to check the switch yet. My email is [email protected].
TANK... Nice to here from you. You gave me some good info when I was lookin for my gun in 04. Do you still have the one you got from Phil with the #3's. By the way, I didn't follow your advice and have put money into the bravo's. All in all, I love my boat. I'll let you know what I find. Hopefully it will help.
Right on brother. You picked up a great boat. Enjoy it and post some pics from time to time.
Let me know how you track down that problem. I think it's the same as mine.
thisistank is offline
Old 10-20-2008 | 02:18 PM
HUSTLEthis's Avatar
Check all your ground wires too..... the connection might be good enough for a little tester, but not good enough to crank the engine....
HUSTLEthis is offline
Old 10-21-2008 | 08:03 PM
chewy1955's Avatar
Registered User
I don't think it's a ground issue. Engine turns fine when jumped at the solenoid, either by 12VDC to the coil or by a screwdriver across the posts. I haven't had a chance to get back on it yet. Been a very hectic week.
chewy1955 is offline
Old 10-22-2008 | 09:59 AM
hurleyr's Avatar
Hurley
On my boat the ignition hot comes from the battery to the fuse panel under the bow to the ignition switch. This should be the same on yours. Make sure the fuse under the bow is working properly and is turned on. Also check connections from the key switch and kill switch.
Nuetral safety switch could also be the culprit.
hurleyr is offline
Old 10-26-2008 | 07:29 AM
chewy1955's Avatar
Registered User
I checked the switches and everything looks good there. I have power and the load side tested identical for both switches. One worked and one didn't. Been tied up with more pressing issues lately and haven't been able to get back into my boat. I now have some additional wiring info thanks to Eric, so if it is not the neutral safety switch. I will be able to do some more trouble shooting. I post what I find.
Old 11-03-2008 | 10:28 AM
chewy1955's Avatar
Registered User
Smile
Finally got back to the boat to winterize everything. Wiggled the shift lever and the port motor started. It was definately the nuetral safety switch. I will tear into it and adjust/replace what ever it needs.
Thanks to everyone for you comments and help. Still would like to get a schematic for the 98 gun if anyone has it. The info on the 90 cafe is a help in a lot af areas though.
Thanks Again
blume
Cigarette
18
07-05-2006 07:02 PM
tblrklakemo
06-04-2006 07:46 PM
Wettin My Shorts
2
05-16-2005 04:56 PM
R-Don
02-19-2005 01:07 PM
Great Dane
Scarab
0
11-29-2003 10:19 AM
