My 20 Cig Project
#61
I would caution you against a small block, expecially if it is lightened with aluminum.
Cig 20's are heavy boats. My Cig 20 was heavier than my 24' Banana boat.
That being said, I feel the weight of a big block, would give you the best center of gravity and center of weight, both very important for stability.
One Cig 20 owner had a small block, lightened the engine up with mods and reported that the boat bow steered after.
#64
Charter Member #139 /Moderator/Platinum Member
if you when with the small block it would also give you the oportunity to add weigh to balance the boat
I am using a 500 HP so I will not have that issue
The only problem I have is it will only be 550-600 HP so I am way down power wise compared to these guys LOL
Kept the Bullet and the condo and joined the cig 20 restoration club.
#67
that would be the question it appears a sbc versus bbc both cast iron is about 200 pounds different you could add that amount of weight in small increments to the bilge area if in fact you got the bow steering affect as someone noted
