Top Gun Questions
Hi I have a few questions about older Top Guns compared to newer t/s.
What is the weight of a kevlar hull 89 as opposed to non kevlar and newer twin step.
Cabins are they really needed how much weight is a full cabin and are there things to look out for that have a tendency to break.
# 6 drives how often do they need to be serviced or rebuilt, and cost.
And big HP blown motors how often do they have to be rebuilt and how much for a rebuild more or less.
You guys are real knowledgeable and I appreciate your help and if you can think of any other differences between the different year Top Guns that would be cool. Thanks
Per Cigarette, our '90 Kevlar with full cabin weighed 10,000 pounds fitted with blown Zuls/# 3 drives. Total weight with 2 people, misc. tools, and 100 gallons of fuel is 11,040. This is probably 700-950 pounds lighter than most regular TRS hulls.
Personally, I like the full cabin and the '90 layout allows 4 people to sleep. The twin sofas also work great for storing guests' bags, etc. for easy access while running. The newer cabins seem to be more suited for just 2 people and less baggage. It really depends on what you want to do with the boat....for me a cabin is a must. If you don't want or need a cabin, maybe a Gladiator would be an option.
As far as rebuilding.....you probably ought to do the valve springs/top end every 250 hours (not too expensive, I recently had it done). A complete rebuild "may" be required at 500 hours, although I've heard of much longer intervals. I think it all depends on maintenance and how hard you are on the engines. That is why it is nice to have a boat that cruises well below 4000 RPM.......
The gears in the No. 6 drives can actually be flipped to run on the other side. I've never had an issue with the 6's other than servicing the prop shaft seals.
Give me a call if you have any questions
I have to have a cabin in my boat. I want to be able to sleep on it, and I want an enclosed bathroom - so that (and my budget resrictions) put me in a flat bottom.
The cabin switch over came "around" the 1990 time frame but be prepared that there are some 1989 boats with the newer cabins, and some 1990's with the older cabin - all depends on when they were stamped and sent out the door.
I believe I remember reading that the weight difference is a few hundred pounds.
Most people aren't cross shopping T/S guns and Flat Bottom guns because of price differences. If the cabin is NOT important to you, and your budget allows either than just get the T/S - it's a no-brainer under those circumstances.
Most guns have notched transoms but I believe there are some EARLY ones that are non-notched.
Notch came out in '89-90 depending on what month the build was, also with the notch came the updated better cabin layout with the facing seats and the counter.
I like the full cabin. My wife and I can sit at the table that face each other and play games at night. Also, it is nice to eat there as well. When you want to have more fun, the bed is just a few steps away.
And no, there was no history of anything breaking or any problems with the cabins on the 90's guns. They hold together really well.
I will assume (since you're not talking about buying a new 39 TG w/1075's) that you are refering to blown 1000 hp motors or the such.
I would say, more maintenance than you want to deal with. Valves should be checked every service and most likely will need to be gone through every 50 hrs.
Light rebuild (no block) are going to be in the ball park of 10k each (depending on what's needed). You'll prob. not get more than 250-300 hrs out of large HP/blown motors (if you are extremely lucky and run mellow).
The T/S's went through their share of changes to up to the whole re-vamp of the 38 and the 39.
