Water flow
Old 10-06-2014 | 07:59 AM
Quinlan's Avatar
Default Water flow
I am having water flow issues on one motor.
We have changed out the impellor- was perfect., back flushed everything.
Problem is that I am not getting good flow to strainer. One has the water going thru like a toilet bowl and Starboard is just about half that flow.
Any ideas? Changing water circulation pump this week.
Quinlan is offline
Old 10-06-2014 | 08:25 AM
CIG3's Avatar
Check your hoses for cracks. I've seen hoses with small cracks cause this problem. Sucking air.
CIG3 is offline
Old 10-06-2014 | 09:22 AM
offshoredrillin's Avatar
i would also look for an obstruction in the drive itself, if something got wedged into the passages of the scx
offshoredrillin is offline
Old 10-06-2014 | 02:48 PM
Quinlan's Avatar
I have been looking for leaks but none noticeable.
Quinlan is offline
Old 10-06-2014 | 02:50 PM
Quinlan's Avatar
I was thinking this also- It started Shootout weekend.
Now how? I guess pull drive? I looked at intake holes in nose and they appear clear. We flushed water back out also.
Quinlan is offline
Old 10-06-2014 | 04:02 PM
cigrocket's Avatar
I had this same issue, I put a brand new mercury pump housing on, it had a casting flaw. When I installed it, in between the 2 bolts that are close, the new housing had a hairline small crack, I thought it was a drip from hose, but it wasnt, I replaced with a borrowed older housing. Full pumping, no problems. Just that little air and it made erratic, half pumping situation. Good luck!
cigrocket is offline
Old 10-06-2014 | 04:48 PM
cigrocket's Avatar
FYI this was 4 weeks ago
Old 10-06-2014 | 04:57 PM
Did you check the connection/ fitting at the transom assy for blockage ?
JaayTeee is offline
Old 10-06-2014 | 05:28 PM
Quinlan's Avatar
Its Dark back there lol. With the Stellings boxes Hmmm. Need to see about that. Might be able to pull hose lose in box?
What size hose is this? I might just get several feet and replace.
As for the impeller housing its the Stainless steel from Hardin( I think).
Bad part is tanks are Full and I do not want that sitting all winter.
Quinlan is offline
Old 10-06-2014 | 05:34 PM
cigrocket's Avatar
Better to fix it now, burn the gas, and be able to sleep at night....lol. I hope it's simple for you, good luck
