My Flat Deck transom replacement and paint project >
Old 03-02-2015 | 08:35 AM
  #81
What about a nice oval number one logo in that blue area ??
ICDEDPPL is offline
Old 03-02-2015 | 08:44 AM
  #82
Looking good Ryan!
SC288 is offline
Old 03-02-2015 | 09:14 AM
  #83
SS930's Avatar
Lots of work, looking good though!
SS930 is offline
Old 03-02-2015 | 02:09 PM
  #84
Carrying the stripe all the way back just looks right. Timeless.
sea6 is offline
Old 03-02-2015 | 04:01 PM
  #85
Dan that will be decal till next fall when it will get painted.
sonic700 is offline
Old 03-02-2015 | 07:19 PM
  #86
Let me free style it for you , I always wanted to be an artist.
ICDEDPPL is offline
Old 03-02-2015 | 07:50 PM
  #87
Originally Posted by sonic700
Jim. I am not even close to a glass guy. What happened was I removed the inside glass and the rotted wood. Then it was taken to the glass shop, That's when it was decided to cut the transom out due to the amount of repairs that had to be done to the outside. When the back was cut out they left about an 1-1/2 all the way around. That's what kept the sides, top, and bottom true. Then the boat and the transom were ground to a 45. After that the inside has multiple layers of glass as well as a couple on the outside. Hope this helps. I can get more specific info if need be.
That's extremely helpful and a great idea! I never thought about cutting out the majority of the glass but leaving enough to keep the stability! Yup, I think that's how I will do my transom! Much easier from the outside! . Your boat is really starting to look good, can't wait to see it done!
Jim
502ss is offline
Old 03-02-2015 | 08:20 PM
  #88
Thanks Jim. If you do not touch the inside fiberglass that will also hold everything together. I would ask someone with more knowledge on how to tie it back in if you are going to go that route. Definitely easier standing.
sonic700 is offline
Old 03-02-2015 | 08:21 PM
  #89
Sorry Dan going to have to practice on your ride. I already have this one figured out
sonic700 is offline
Old 03-03-2015 | 09:25 AM
  #90
What did you do about the HIN#, did you cut around it or remove it. I only ask because I recently went to look at a boat that didn't have a HIN # on the transom. Thanks
TURBO JET is offline
