my pfaff large oil pans  hit rear cross stringer .. >
Old 11-05-2015 | 08:02 AM
Dude in the vid sounds like Don LaFontaine, the voice over guy.
ICDEDPPL is offline
Old 11-05-2015 | 09:01 AM
When your done you want about an inch of clearance. Others can chime in but if it were mine, I would cut the stringer down and radius the top. place around 3 or 4 layers of 1708 cloth going 2 or 3 inches out on the floor on each side of the stringer to maintain the stiffness. Grind off the gelcoat in the work area.
kvogt is offline
Old 11-07-2015 | 10:25 PM
Smitty's Avatar
Make sure that there are no sharp angle cuts. Radius whatever you do. If a sharp angle, good place to crack and splinter. As others have said, add glass mat on either side.
Smitty is offline
Old 11-08-2015 | 08:55 AM
Makes me cringe when people say cut the stringer. I'm guessing it's too late to get another oil pan?
1MOSES1 is offline
Old 11-08-2015 | 11:14 AM
ROB FREEMAN's Avatar
Yea. Much to late. It was just a cross brace. Took 1 inch out of it. Regal asked with mesh. At the very back of boat. It will be fine. It's not like I'm out in 8 footers. Even then it's rock solid
ROB FREEMAN is offline
Old 11-22-2015 | 11:02 PM
Structurally you are probably fine...I was thinking re-sale. Surveyor will pick up on the modification and flag it as an issue possibly killing a potential deal. Sounds like it's too late anyways. Good luck with her!!!
1MOSES1 is offline
