Trim ram line question.
Update..., I’m trying to definitively identify WTF size and degree theses inverted flare fittings are. I believe what I have here are #3 to #4 37 degree fittings. As mentioned, In the early 90s Cigarette used Parker hoses for their drive trim lines from the pump back to the divider block on the lower portion of the outter transom assembly. I cannot seem to locate these fittings. Local NAPA had what seemed to be close but as far as I can tell they are 45 degree brake fittings and wont seal correctly. Can anyone point me in the right direction. I’m pretty rural so “going to the local parker dealer” or Hydro shop is not an option. I called Marc at Bam, he wasnt much help. Thanks.
