Cigarette adventure (new transoM and #6 conversion)
#85
#86
Dan have you thought about cutting the flange between the bung and the edge and adding a small wedge to close the gap . That one inch section is not doubled walled cooled and would be an easy weld for an experienced TIG welder . Might save a lot of grief and aggravation . May *uck up the powder coat though . Just a thought . RG
#87
Thoughts ... mike ?
I have room:
secondly that`s going off a foam block and heads ,,not sure if I should wait till real engines are in but then I`m rushing in the spring. rather make stuff over winter.
#89
Went through that on mine....had to redo the transom holes and modify my tips to match up with the port height difference. Luckily I was redoing my transom anyway so it wasn't that big of a deal but still good to think about if the foams are standard height.
