She's finally here....... 29' Mirage for restoration. >
Old 08-27-2007 | 08:24 PM
  #61
h2oboater's Avatar
Originally Posted by lightning jet
I just gave a freind of mine a 1979 29 that had trs small blocks in it he is do a resto with small blocks and bravos ..........emi ex can be cut to fit 29 1/2 centers and still clear a tall high rail valve cover ............................I have a two sets for sale new
The Mirage you gave away, was it red and white, and did look like this.
h2oboater is offline
Old 08-27-2007 | 08:43 PM
  #62
h2oboater's Avatar
Originally Posted by spectras only
Boostedscarab , I don't have a 'real' Mirage you guys talking here , just want to throw my 0.02 cents here . Since you've decided on twin small blocks I'd suggest to get the Bravo X
with 1.65 gears to have room to play with bigger props .
I have a 1990 Mirage 257 with 377's w/smartcrafts , Bravo X drives 1.65 ratio, spinnig B1 26 P blades [ tuned to true 26 P] at 5000 rpm .. My boat is only 24' if you minus the built in swimstep . Your boat is a true 29 and prolly a brick, so it will need the 1.65 ratio if you want to get on plane quickly. I wonder what your boat weighs at the scales ? Mine weighs around 6800 lbs without trailer .
According to my Mirage brochure the 29's weight is 5200 lbs.
Attached Thumbnails She's finally here....... 29' Mirage for restoration.-scan0010-mirage-facts.jpg
Old 08-28-2007 | 12:34 AM
  #63
5200 lbs with twins ,pretty light .Should do well with tw 383's
if it did 60 with much less power before .
spectras only is offline
Old 08-28-2007 | 01:06 AM
  #64
h2oboater's Avatar
I think my twin big block Trs Mirage is more like 5800 lbs.
Old 08-28-2007 | 10:52 AM
  #65
Question
H2O , twin BB with TRS's must weigh close to 2500 lbs .
Your hull with all the rigging weighs 3300 . What's
the layup like on these older Mirages , some kevlar ?
Old 08-28-2007 | 10:12 PM
  #66
h2oboater's Avatar
No kevlar, just good old polyester resin and glass cloth. Remember these old girls don't have sinks, refrigerators, and the extras most boats have today. I guess that's way there still around 30 years later. Make it simple, but make it FAST,& Last,, at least to the speeds of the 70's.
Old 08-29-2007 | 09:28 AM
  #67
looks pretty close ....no race numbers though
lightning jet is offline
Old 09-27-2007 | 01:29 AM
  #68
Smile
H2oboater , I thought you may want to save this picture I found in one of my mags from 1978 .
Old 09-30-2007 | 10:43 AM
  #69
If this boat was originally a blue hull with a blue Eagle tri-axle,then later painted red with multiple colored taped stripes,I have this boat in my shop. I have gutted it completely,put a new transon in it,cut bravo openings,and it now has a white hull and ared sheer. Kick-ass small blocks are being built and should be ready to put in this year.I have a ton of pictures to post soon and would invite all and any backfeed on this really cool boat!
sunset bar is offline
Old 09-30-2007 | 12:17 PM
  #70
h2oboater's Avatar
That is my old Mirage, I painted her sides red with the stripes. This Mirage's first owner was Bob Johnson who also owned Eagle trailer at the time. I believe he raced her in the ABBA P-class in the late 70's. He had her untill the mid 80's, and then sold her to a guy in Port Huron Michigan. I bought her in the spring of 1988, by then the deck was already repainted white. I ran her that year with the faded blue gel side's, and just a good clean up. Over the winter I did a rebuild on the engines and a mild cam change, and also cleaned up the bilge & rigging. Ran her in 1989 in APBA A-class that year in calm water, with full interior and had FUN. Sold her around 1995 for a 38' Scarab and always regretted that. Sold the Scarab this year and went back to a 29' Mirage and hope this one run's as good. I talked to John [jet] and even bought from him the old trs wing plates just to have a pice of that great boat. Post some pic's, love to see her be reborn again.
