Don Aronow Memorial Race
#81
Remember his brother Roy also, I`m not sure if he is even alive, John Steinbach, Marty Businger, Johnnie Backus, heard he was working out of Fond du lac airport on his plane. I`ll try and get Stuteville to come, let`s not forget Bobby Moore. and Mike Ramsey, the list goes on,
#82
Charlie has the dimesions. The numbers will be assigned and given to you upon registration. If you have an existing number include it with your registration form. However the assignment of numbers is based upon class and date of registration reciept.
#84
Ryan ,
Contact Charlie asap ! He still needs stickers for the race .We also need some HORBA event stickers for all the boats .
Do you know anyone with great prices for Banners ?We will need alot of banners too !
Thanks,Larry
charlie - www.historicraceboats.com
larry - www.xtremepowerboats.com
Thanks,Larry
#89
The numbers that are already on the race boats will be allowed to be used.
If two boats have the same number, the boat who registered earlier will keep his number and the second boat will have to have a new number assigned.
Because of that, we are having decals made up that will have the word PARTICIPANT across the top. The bottom will be split with Don Aronow Memorial race info on one side and HORBA on the other.
These will be the "Official" stickers for the race boats only.
For those boats that don't have numbers; Numbers shall be black on a white background. If on a white hull, they must be surrounded by a black border. Minimum height of each number shall be 18 inches, minimum width (Except for 1 ) shall be 13 inches, minimum stroke shall be 3 inches and minimum spacing between numbers shall be 7 inches.
Ryan, we could use your help to make any of these numbers at the last minute in the pits for the very late entries.
