Bringing Back A Legend (Rascal) >
Old 05-25-2012 | 07:35 AM
  #61
540 N/A's? I'm guessing about 575-600/ea. I've never seen a straight out the back set up (I'm young give me a break) how will it run?
machloosy is offline
Old 05-25-2012 | 02:07 PM
  #62
Yes that is about right. I am designing a belt drive drop box that will allow the shafts to be straight with the bottom and run surface drive props with a rudder. Almost like a belt drive engine on a harley or a super charger belt on steroids. Concrete crushers run off simular belts. The drop box will have an upper and lower jack shaft That the 13/4 prop shaft and trans will couple to and the belts will connect the jack shafts with pullys. This also allows gearing options. This system also allows the engines to be mounted outbound with the shafts close together. The drop box will be tied into the stringers and the force of the prop shafts will be pushing on the drop box and stringers instead of the trans and engine like an inboard set up or the transom of an out drive system. It has a oiled tapered thrust bearing in the front of the box frames and water cooled. Good stuff!
legend is offline
Old 05-25-2012 | 03:59 PM
  #63
That boat is going to be wild! Plus gearing options is too cool
Old 06-26-2012 | 02:22 PM
  #64
Default weight dry
If my math is correct 5,600
Math was wrong. 3,700 without engines and drives.
legend is offline
Old 07-11-2012 | 07:22 PM
  #65
Started refinishing the sides. Slowwwwwwwwwwww Process!
Attached Thumbnails Bringing Back A Legend (Rascal)-rascal-001.jpg   Bringing Back A Legend (Rascal)-rascal-002.jpg   Bringing Back A Legend (Rascal)-rascal-003.jpg
legend is offline
Old 07-12-2012 | 06:46 AM
  #66
TENSION's Avatar
Gives new meaning to "that'll buff right out" ! Wow ! Looking good !
TENSION is offline
Old 07-13-2012 | 12:57 PM
  #67
I would love to come check that thing out if I'm ever up your way. What a wild package, too cool.
frickstyle is offline
Old 07-13-2012 | 02:06 PM
  #68
Let me know. I'm just south of Rt.90 and Geneva.
legend is offline
Old 07-13-2012 | 02:10 PM
  #69
Few ripples and war wounds but that keeps it true to it's days.
legend is offline
Old 07-14-2012 | 01:27 AM
  #70
J-Bonz's Avatar
Heck, you could see the boat and the traveling troubadour Alex Bevan all in one day...........
J-Bonz is offline
