GLOPRA Pictures
Old 02-29-2016 | 07:18 AM
  #241
CIG3's Avatar
I raced in the boat with the bravo's it was a handful. My opinion was they mounted the drives way to high. On boxes they were around an inch above the bottom. This caused the boat the want to chine walk and run nose high. They ended up adding ballast to the nose which helped some. I liked the way it ran with the Arneson's much better. it just needed propped better which was a lot of cash back then.
Originally Posted by HTRDLNCN
Yup,I have that pic ,, looks like it was riding pretty neutral there which is what you want.
On the 36 race boat what Sal Picon did was run air lines from the top to vent the steps.
Worked well but the 36 was twin step .
Im also re-installing the ballast tank back in the front in case the big blocks make it a little nose happy..
Like I said it will just be a fun poker run boat so its probably not gonna see the seas or speed it used to, if I can get mid 80s out of it Ill be tickled pink. Its still a very solid boat and being the only one ever made makes it all that much more interesting..
CIG3 is offline
Old 03-02-2016 | 10:01 AM
  #242
great pics
term1032000 is offline
Old 03-08-2016 | 06:47 PM
  #243
bck's Avatar
bck
Charter Member#568
ohhh i was schooled by someone from the area that berated me for pronouncing the "T" in Mentor . . . ever since then it has been Menner . . . .
I stick to the lower class neighborhoods. I know there is no "g" in Collinwood
Straight bottoms and flat decks
bck is offline
Old 03-08-2016 | 08:02 PM
  #244
J-Bonz's Avatar
Yeah, but there are alot there that think they are "G's"....
J-Bonz is offline
Old 04-12-2016 | 05:07 PM
  #245
[ATTACH=CONFIG]553986[/ATTACH].
Mad Mother, Cheap Thrills, L.A. Express is almost complete and 1400 LBS Lighter
legend is offline
Old 04-13-2016 | 12:03 PM
  #246
scippy's Avatar
Great job she looks reborn!.......where did you shed the weight?............I know you lowered the cockpit sole, what other improvements did you make?
scippy is offline
Old 04-13-2016 | 01:18 PM
  #247
TENSION's Avatar
Lose an engine?
TENSION is offline
Old 04-14-2016 | 06:06 PM
  #248
Cig 3 was the arneson drive setup you mentioned spinning in or out. Thanks for the info. I'm rerigging my boat with Arneson s. Similar bottom. Cary 29'9"
Cary 29 is offline
Old 04-15-2016 | 10:55 AM
  #249
CIG3's Avatar
Spinning Out
CIG3 is offline
Old 04-15-2016 | 04:35 PM
  #250
Thanks probably 3 blades? I was told to spin in. I'm running 4 blades though with big diameter.
Cary 29 is offline
