Need HELP!!  With 496 HO runs bad >
Old 06-29-2008 | 02:02 PM
Default Need HELP!! With 496 HO runs bad
Hello I'm new on here and I have a problem with one of my 496 HO's can anyone help I'll appreciate it.
Here is the problem, at high rpms, underway the starboard motor boggs at 4000 to 4500 RPM's but it runs fine at 3300 rpms, and idle. I've changed my plugs, and wires and put it on a scope and no codes. I do notice one thing my port side motor purges and hisses while the starboard does not, could this mean something? What should I do next guys. Thank you
parkster747 is offline
Old 12-28-2008 | 04:13 PM
I had a similar problem on my 496 HO, it turned out to be the Idle Air Control tube had come loose from the intake. It was located at the rear of the motor on the backside of the manifold. The "hissing" is the air leaking into the manifold. I resealed mine with Loctite and have not had any problems in the last 2 years.
gttaply is offline
Old 12-28-2008 | 07:43 PM
Not sure how loud your hissing is but if the little piece of foam is missing from the throttle body it will cause a light engine lope and on/off hissing that will be consisent with the lope itself...
Run the other engine with the scanner hooked up on plane and see what data you get when the rpm's drop back like you're saying... Could be light guardian mode compensating for one of the vitals.
SDFever is offline
Old 01-05-2009 | 01:32 PM
BryanTuvell's Avatar
Donzi33ZX
I would check the fuel injectors.
Bryan
BryanTuvell is offline
skaterjim
03-03-2006 11:08 AM
89scarab3
Prop Talk
1
07-02-2005 04:48 PM
Waterfoul
04-21-2005 07:47 PM
dreamer
04-11-2005 05:32 PM
Maximus
02-12-2004 07:59 AM
