Water Pick-up
any ideas on water pickup concern for bravo sea pump, i cannot get it to pull water from strainer, have burned out 2housings and impellers.i can fill the strainer manually and the pump will pull water but it will not draw from the drive, if i put a garden hose on the flush coupler it runs fine
Did you just install the strainer? if you plumbed it backwards you would have exactly the problems you are describing. The water should enter the strainer through the upper fitting and then flow to the sea water pump through the lower fitting.
Looks like you found your problem.
In addition, stay away from the Sierra branded impellers. Installed one on a buddy's boat and could not get it to pump no matter what we did. Replaced with Mercruiser and all was well.
Waterfoul
04-17-2003 08:01 PM
