Overheating at speed
You might be surprised when you look through it.
They are either plastic or aluminum.
The plastic ones are one piece with 1 SS plate and the aluminum body ones are 2 pieces with 2 SS plates.
Aluminum one is first on page, plastic is second on page.
http://boatfix.com/bykeywordmerc.asp...kit&texttype=2
Here is what mine looks like:
I put everything back together and guess what? It does not overheat. Yeah.
The engine is running 10 degrees hotter than the other one, port = 145, sbd = 155, so I'm pretty sure I still have a restriction in the oil cooler.
If I can just get through the rest of the season, I'll pull it all apart this winter.
Thanks everyone for helping.
oil cooler!!
especially if around low water levels and sand
I back flushed, removed hoses, new impeller and housings and still the same thing!
even went after the hose in the gimbal/drive connection.
nothing helped!
until i pulled the oil coolers off and found to have only 3 open channels!!!!
took a lot of coat hangers/patience and pushing-pulling and pounding to get them clean.
However it all paid off because now they run cool and I did not have to spend $287/each for replacements
nothing helped!
This Cat is trying to keep up with the Big Dogs
oil cooler!!
nothing helped!
nothing helped!
I have had similar problems
Problem was the feed hose to the sea pump was being sucked closed when it higher rpm when more suction was created - collapsing the hose.
The problem caused impeller failure and caused the pieces to be clogged at the cooler-back flushing eliminated the large chunks from the system-however there were some that were clogged at the thermostat-also there were some that "melted" their was thru the system.
Anyway, the hose would not collapse on the garden hose, just under a load when in the water under power. check that system for faults. Possible - trying to help
Good luck
Good luck
