Best option for more speed >
Old 03-12-2010 | 11:43 AM
Best advice I have ever heard. "If you want a faster boat, buy it."
The thousands you spend to pick up a couple miles per hour would go a long way towards changing boats and gaining 20 mph. Been there, done that....
Kieffer4 is offline
Old 03-20-2010 | 05:12 PM
i had a fountain fever 27 502 with a pro charger and it would run 82 top end easy. Had about a season and a half. Never had a issue with it. Fast as hell.
38Lightning is offline
Old 03-20-2010 | 05:31 PM
I don't know about that... Most of the people on here need aftermarket crap to go faster. I would rather bolt my own parts on my boat, and know its history than buy something that someone else hacked together.
wjb21ndtown is offline
Old 03-20-2010 | 05:44 PM
Number put a good labbed prop on bblades might piuck up 3 or 4 . If you want to put on some dart heads 1500.00 and get ecu programed and i might get you there, before you do anything try a blade it make a big differnce
fastscarab22 is offline
Old 03-20-2010 | 06:40 PM
Originally Posted by 8luglogic
I have an 27' Fountain Fever , stock 502mag efi with a bravo 1drive with 240 hrs . Fastest speed under ideal conditions is 69mph but it can run 65 mph consistantly . Overall i'm happy with the boat as is , that is until my buddy passes me in his aluminum river boat with a jet drive . It just don't look right having an ugly ol' campertop jetboat whooping a performance boat like a Fountain .
Am I best to go with a new engine & drive combo or can the 502 and bravo 1 be upgraded and still be reliable ?
I get so many differing opinions from friends that I'm not sure what to do . Ultimately I would like to find the best setup for the 27' Fever , to get it up in the mid to high 70's or better .
Lots of factors to consider when going past 70 mph and added HP, reliability is key. Stock Bravo will be your week point for sure as well as your base engine components, Raylar kits are very good as well as a whipple install, keep in mind added external steering will be a must as well as a good exhaust, all high dollar parts so need to do your homework on existing 27's and what set-ups they are running for comparison to match your end expectations. If 80 is your goal then see what it takes to run your hull at those speeds reliably and safely and do your research before you start the grocery cart method, JMHO.
laszlo01 is offline
Old 03-20-2010 | 08:11 PM
cigboat1's Avatar
8luglogic, Why do you care if some guy in a John boat goes faster than you ?????Nobody looks at his boat ,they look at your Fountain going by...The guy probably weighs a third less than you, has a flat bottom and is shorter than your boat... you also have to push a 24degree hull around. Ask your pal to come out and play when there is a three or four ft. chop----see what happens then!!!!
Last but not least you better have a truck load of money to sink in the boat if you want to go faster.. Jim
cigboat1 is offline
Old 03-31-2010 | 11:50 PM
Well it just don't look right having a riverboat pass a Fountain .
He's a buddy and he's gave me a bad time about my Fountain for years .The Fountain being a performance boat and not being able to school a small block jetboat just looks bad .
So ... If I decide to drop a pile of cash in to this thing what is the best and most reliable way to hit 80mph . What drive will work best and hold together ? I think I'll keep my existing 502 & Bravo1 for when I decide to sell the boat . I may bump up to a 29' Fever one day .
8luglogic is offline
Old 04-01-2010 | 08:25 PM
I'd get a super charger before I got a new wheel... Get a prop to match your power, don't get a prop and then power up...
