spread bore carb to square bore intake >
Old 10-21-2010 | 09:46 PM
Default spread bore carb to square bore intake
what the phuck should i use to adapt my qjet to my edelbrock performer rpm intake? all i can find is stuff for single plane intakes
87MagnumII is offline
Old 10-22-2010 | 12:49 AM
You shouldn't. You should get square bore carb. The adapters hurt performance a lot.
Griff is offline
Old 10-22-2010 | 05:52 AM
I agree...dump the q-jet
ezstriper is offline
Old 10-22-2010 | 06:34 AM
how do the carb adapters hurt performance? I found this one and it looks to be ok.
http://www.summitracing.com/parts/SUM-G1401/
or any suggestions on a 650 cfm squarebore marine carb would be helpful, something that doesnt require a lot of mods to make it work correctly, i have heard horror stories about stuff not fitting right
Old 10-22-2010 | 11:47 AM
That one may be ok. A lot of the ones I have seen have a funky offset.
Griff is offline
Old 10-22-2010 | 04:52 PM
would not worry about the adapter as much as the q-jet hurting performance ...and if it does not have a elec choke as most do not..GFL there...
Old 10-22-2010 | 05:43 PM
I just ordered 2 Barry Grant marine carbs off e-bay they're pricey but totally worth it and they look awesome
andyt25 is offline
Old 10-22-2010 | 06:00 PM
CPPerformance's Avatar
We have the adapter also if you end up needing it......
http://www.cpperformance.com/p-13329...r-adapter.aspx
CPPerformance is offline
Old 10-22-2010 | 06:11 PM
Default Fixx
i dont know it you have thease http://compare.ebay.com/future/39024...=263602_304672 But if it is the one in the pic shown you dont need a adaptor, the intake is drilled for both a 4150 and a q-jet..
FIXX is offline
Old 10-22-2010 | 06:16 PM
that is the intake i have but mine is the 7116 vortec version which is only square bore
