winterizing
Old 11-05-2010 | 08:33 PM
not to mention the slime left behind from the pink stuff.
FIXX is offline
Old 11-09-2010 | 11:34 PM
I like pink tacos.. not any that leave a slime thou
ICDEDPPL is offline
Old 11-11-2010 | 08:09 AM
Been using pink for years with no probs! On 4 boats, 2 jet skis, and a camper! Slushes up but doesn't burst... yet!!! Knock on woodie! Where's my pink??!!
johnnykool6 is offline
Old 11-11-2010 | 10:21 PM
funny....... i thought all pink tacos were a bit wet and slimmy....
Centsless is offline
Old 11-13-2010 | 03:55 PM
Pink is great as long as you properly drain everything out of the systems.
The Pink has no rust inhibitors.
West marine has one or two levels above the pink that has rust inhibitors AND IN THE SPRING YOU CAN START THE BOAT AND LET THE STIFF GO, IT IS NOT TOXIC.
Personally I dump in a 50 50 mix of regular antifreeze after I drain everything, it is toxic, so I drain it out in the spring test it and then reuse it the next winterization.
Regular antifreeze will keep the motor interior coated with the rust inhibitors and be the best you can do as long as you don't dump it in the spring and reuse it again for your next winterization.
Good Luck
Brian
Big Boys Toys is offline
Old 11-13-2010 | 06:33 PM
Good Luck
Brian
Best deal right here if you need to winterize the engine blocks. I never used the pink stuff in the blocks, for the exact reason you mention. On these closed cooling 525's the "real" antifreeze is already in the blocks, so I do use the pink to do the coolers and exhaust systems. I do drain the water first, then run it thru, just to be sure it is good to go. I'm in heated storage but do not want to worry if the heat goes out because of a winter storm. The pink stuff is fine,IMO, for this purpose. Again would never use it in the blocks, nothing like the old green toxic stuff for that.
RaggedEdge is offline
Old 11-14-2010 | 10:11 AM
Cool green stuff
glad i live in texas wheres it doesnt get that cold an fresh water
sure dont want my dogs or the fish drinking that toxic stuff,all i do is drain em,add stabil an fog an let em sit....
kubelwagonman is offline
Old 11-15-2010 | 06:41 PM
Dave M's Avatar
Veteran: Navy
What about fogging the engine? With my 454 Mag MPI and 496HO, I didn't bother to fog and never had any issues.
Now with a 525 I have a little more invested and don't want to take shortcuts.
Dave M is offline
Old 01-12-2011 | 08:17 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Interesting
US1 Fountain is offline
Old 01-13-2011 | 08:52 AM
Same stuff I use.
I guess if my boat was winterized from Labor Day till Memorial Day, I would put regular antifreeze in it that does have better rust inhibitors in it.
redbud35 is offline
