winterizing
Old 01-13-2011 | 01:01 PM
That's IS the stuff!! Been using it for years with no problems!!! Looks like it's working!
johnnykool6 is offline
Old 01-13-2011 | 03:47 PM
Here's the pink stuff after two days of temps not much over 0 degrees and some pretty bitter wind.
http://www.youtube.com/watch?v=cVwCh...tailpage#t=25s
It's fairly solid but, as someone mentioned, that doesn't mean it has expanded.
Dredd is offline
Old 01-14-2011 | 09:14 AM
Hey Dredd, Nice one on the pink stuff. So in reality you can get away with it providing you get all the water out of the system . Looking at the video, just a little more water in the gallon jug and you will get a freeze, now you have lost a motor, or manifold or cooler. After they freeze and you thaw them out, now starts the real fun, trying to save the motor. What actually failed ?
Big Boys Toys is offline
Old 01-23-2011 | 03:13 PM
Gordo's Avatar
Charter Member #94
If you completely drain the system, then why would you want to turn around and add any antifreeze?
If the answer is "so it won't rust", then why not just use "Sierra" (dog-safe) anti-freeze to begin with?
Sorry, but I don't trust the pink stuff. Ice is ice whether it's solid or not, and when ice melts it expands. When it expands, it breaks things.
Personally, I hook up, start and run the engine on the hose long enough to warm up and open the thermostat.
Then I disconnect the garden hose and hook up a short hose (customized by Gordo) that draws from a 6 gal. bucket of 50/50 Sierra mix, (good to -30* below). Fog the engine the last 3-5 seconds just as it draws the last of the anti-freeze mix.
The first couple of times I did this I still pulled hoses off the exhaust just to make sure.
Now days, I've got no worries or second thoughts, the inside of the heads, block, oil/steering coolers and exhaust are all covered and protected. The next spring I trickle charge the battery for a bit, hook up to the hose, fire it up, warm it up and head for the lake.
Abby-someone
Gordo is offline
Old 01-24-2011 | 08:20 AM
Interesting!
Although, windchill has no effect on it.
redbud35 is offline
Old 01-24-2011 | 10:53 AM
Gordo's Avatar
Charter Member #94
It's not the actual "freezing" that does the damage. It's when the ice starts to thaw. Ice expands as it thaws. THAT's when bad things happen!
Abby-someone
Gordo is offline
Old 01-24-2011 | 11:41 AM
Knot 4 Me's Avatar
Water expands when it freezes. That is when the damage is done. I drain all the water, run pink through, then drain the pink.
Knot 4 Me is offline
Old 01-24-2011 | 11:43 AM
I'm no engineer... wait... yes I am! Water expands when it's thawing... that's true... BUT>>> when water changes from a sloshy liquid to solid ice, it expands! And that's when it does the most damage!
http://i586.photobucket.com/albums/s...6/DSC_1571.jpg
I hear cracking as we speak!!
Old 01-24-2011 | 11:50 AM
Nice Photo Johnniekool
How ever you cut it, once you have tried to cheat and improperly winteized, if have it wrong , it will be a costly spring.
Suppose to warm up tomorrow to 31 degrees, like summer.
Have a great day.
Old 01-24-2011 | 04:23 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Millions of boaters and RV'rs must be mistaken then.
US1 Fountain is offline
