Must be the day for starter questions? here's mine! >
Old 04-21-2011 | 12:31 PM
Fountain4402's Avatar
Originally Posted by n20michael
Where would slave solenoid be? On the starter or remote? Boat is a 1996 Baja, single 454EFI B1 drive,
Anyway to test it? Would a "regular" automotive solenoid work? What would cause it to only act up when it was cold?
Michael
by the red reset button on top of the engine
Fountain4402 is offline
Old 04-21-2011 | 12:36 PM
Great! Anyone have a part number?
I looked online and the ones I could find on Ebay looked just like regular automotive style remote solenoids, could I just use one of those? Or are the marine/Merc ones different?
Thanks!
Michael
n20michael is offline
Old 04-21-2011 | 02:33 PM
blue thunder's Avatar
Scroll down in this thread to where I posted a link to buy the solenoid.
http://www.offshoreonly.com/forums/d...st-posted.html
blue thunder is offline
Old 04-21-2011 | 06:54 PM
I had similar starter issues. It was the wire going to the slave solenoid. In the main engine harness connection towards the back of the motor. Had to cut the wires and connect them outside of the big connector.
rchuntlsl is offline
Old 04-22-2011 | 07:17 AM
Thanks!
Michael
http://www.mercruiserparts.com/Selec...asp?class_id=1
find your part number than search for it on ebay. this website isnt to bad priced. But you can find it cheaper in other places
Old 04-28-2011 | 01:16 PM
had the same intermittent problem with my '90 454 bravo1 baja before a 3 year stringer rebuild. so last year i tracked it down to the slave solenoid also. I just replaced it with a 12 volt solenoid from murrays auto, with the same wire posts on it, but I had to cut the bracket on the solenoid because its mounting holes where father apart.
how ever a freind of mine had a 350 with an alpha 1 and his whole engine would cut out on the lake, his issues was the throttle/shifter cable rubbed thru and ground out his nuetral saftey switch or something like that.
cadmonkey928 is offline
