speedo not working
Old 04-02-2012 | 05:53 PM
Default speedo not working
Bought the boat last yr and its the only thing that dosent work. Any ideas boat is a 94 29ft scarab with twin 350 and alpha one gen 5 outdrive?
chevytrucks94 is offline
Old 04-02-2012 | 05:54 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Does it have a gps speedo or a pitot style one that has a tube down in the water, or a paddle wheel style?
John jr
Fenderjack is offline
Old 04-02-2012 | 06:09 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Check the speedo pickup hole for blockage. Should be able to stick a paper clip in the hole no problem.
Or check the tube connector when you raise the drive fully up. Gotta determine which drive they are using for the speedo thou. Unhook the hose at the speedo and see if you can blow air backwards thru the tube.
BTW, it a Gen 2
US1 Fountain is offline
Old 04-02-2012 | 06:24 PM
That's what I ment gen2 sorry typo, yeah has tube down in water. I will check some of that stuff out when I get in the boat next time.
Old 04-02-2012 | 06:42 PM
1 MAIDEN AMERICA's Avatar
I used to use a small drill bit to get the wood out of the drive pitot. Wanna go faster? Drill it larger.
1 MAIDEN AMERICA is offline
Old 04-03-2012 | 05:16 AM
heck, run a 1 inch heater hose to the speedo. you will break the sound barrier!
dereknkathy is offline
