3 deep cycle or 2 deep and one starting? >
Old 04-15-2014 | 07:35 PM
Default 3 deep cycle or 2 deep and one starting?
I noticed that a couple of my batteries are due to be replaced. I have been running three deep cycle and it has been working well.
Looking at my options today, I'm wondering if my single starting battery should be a starting battery and not a deep cycle? I have the other two on a circuit for my sound system.
I am guessing if it isn't broke don't fix it, but I'm curious at least for my education.
Captain YARRR is offline
Old 04-16-2014 | 01:22 AM
I would get one marine starting battery.
Starting or dual purpose batteries are designed to be maintained at a certain voltage and have more cranking amps.
Deep cycles are designed to be run up and down frequently. They like a slow charge rather than being charged with a 65amp alt.
Griff is offline
Old 04-16-2014 | 08:59 AM
I'm guessing I also take a pretty good amount of weight with the smaller battery too.
Old 04-16-2014 | 09:24 AM
Knot 4 Me's Avatar
I agree with Griff. I want a marine starting battery to run the engine(s) and deep cycle for house batts.
Knot 4 Me is offline
Old 04-16-2014 | 02:01 PM
Looked at Cost Co. They label their big batteries "starting/deep cycle." Is that a contradiction?
750 mca 115 amp hours for $85
Old 04-17-2014 | 02:29 AM
No, they are dual purpose, but really are a deep cycle.
Here is an Interstate chart showing the differences http://www.interstatebatteries.com/c...o/marine_f.asp
Notice how the cranking batteries have a lot more CCA/MCA compared to the same size deep cycle.
Griff is offline
Old 04-17-2014 | 06:21 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Been using 2 group 27 deep cycles as house/start bank on 1 motor and a group 24 start battery on other motor for yrs no problem. Using 27's for the reserve capacity since the cruiser has a different demand than the Fountain
I don't get caught up in the big CCA numbers cause I'm not boating when it's zero deg outside where the CCA is more of a factor.
The Fountain has group 24 battery's and turn the 502's over just as good as the previous 27's did.
US1 Fountain is offline
Old 04-17-2014 | 07:42 AM
You can't beat a good AGM dual purpose battery IMO. The big CCA starting batterys have a big downside and you should only need them if you really have an engine that's especially difficult to spin and start. A modern fuel injected marine engine should not need a specialty starting battery.
NightHawk is offline
