Throttle conversion
Old 03-09-2015 | 09:41 PM
That looks a million times better. Nice work!
79formula is offline
Old 03-14-2015 | 05:00 PM
Originally Posted by Mike77
Finally got the new Kiekhaefer throttles installed. As you pointed out the old unit was a Morse and therefore no cable change was required. I got lucky and the throttle set I got had a set of four cable ends with it.
All I had to do was enlarge the mounting hole, attach the cable ends and cables, and adjust the rigging a small amount for all four cables. Very straightforward job. Thanks for the advice.
Mike
Looks great! Just watch out not to grab the wrong lever. My first dual lever, I had in reverse and tried to put in neutral and grabbed wrong lever.. vvvrrrooommm... didnt hit anything, but it was close!
nailit is offline
Old 05-06-2015 | 08:21 AM
Mike
Where did you find yours, I need one for a 77 scarab 300.
koryk is offline
Old 05-06-2015 | 07:42 PM
Ebay
Mike77 is offline
Old 05-06-2015 | 07:45 PM
I'm not sure what to look for. I have the same style throttle you had, I have TRS drives and they shift electronically. Most of what I have found shifts with a cable. Any suggestions?
Here's some photos of what I've got.
img hosting
jpg images
upload a picture
Ignore the horibe wiring the boat is under construction!
koryk is offline
Old 05-06-2015 | 10:38 PM
Unfortunately, no. My setup was 4-cable, two for throttles and two for mechanical transmission shift. I have not seen an electrically shifting setup. The only electrical in my setup are the switches for starter lockout, when not in neutral.
Mike
Mike77 is offline
